The aero in 2B and clubsprint are different, however not a big issue to have 2 splitters.
Should have the weight of the shell on the weekend and this will be the starting point!
Planned jobs
- find seat and have it fitted
- fit CAMS cage
Tim_cyc03 wrote:804,I'm assuming that this is applying the extra 10% for an Naturally Aspirated car on the listed MX5 NA weight...
I don't think it is actually possible. Please I would like to be proved wrong, and I don't like being a negative nelly.
Yes - not in the budgetplohl wrote:Can you go billet block in club sprint?
Clubsprint engine has to be from the same manufactrer and have the same number of pistons. In the MX5 I can use any 4 cylinder mazda motor. The Mazda 26B four rotor is considered a production engine by the promoter.plohl wrote:and have the block based off a k24... with a honda head...
Ginetta is NOT listed, would have to ask...plohl wrote:Maybe it might be cheaper to buy an ginetta?
Magpie wrote:Clubsprint engine has to be from the same manufactrer and have the same number of pistons. In the MX5 I can use any 4 cylinder mazda motor. The Mazda 26B four rotor is considered a production engine by the promoter.
That is correct from the same maker and same number of cylinders. I could ask about is a 4 rotor engine the same as a 4 piston... they both have the number 4 in them...hks_kansei wrote:So does it just need to be a factory block? and apart from that, it's open slather?
