01/10/18 - Dodgy Day (Queensland)
Postby Magpie » Thu Aug 30, 2018 10:12 am
First dodgy day for 2018. PM for address.
The Dodgy Day address will be at the same address (Purga) will start early and finish when it finishes. Normal requests please bring some smally eats/drinks if you can (or want to). No problems with bringing tools are anything else that will make the dodgy day a 'fun' day. Maybe Lokiel will attend and bring his small smoker...
If you have a large job to be done please let me know so that we can make sure the right people are available. Notwithstanding the previous NO CLUTCHES, you know who you are that caused this rule to be made...
It is possible to fit in doing a complete suspension setup (set damper length, set ride height and corner weight) on 2 cars. First in best dressed on this. It would be appreciated if the first cab off the rank can be here nice and early.
Jobs:
Gladiator wrote:Could be a day for a dash change out. I wouldn’t mind corner weighting but no height adjustment needed. Also wouldn’t mind slightly rolling my guards.
Have a guard roller and heat gun, however I have no experience rolling guards. Dash change (yes), corner weight (yes)
ManiacLachy
Re: 01/10/18 - Dodgy Day (Queensland)
Postby ManiacLachy » Thu Aug 30, 2018 11:44 am
Dibs on the scales for weighting and heights! I'll show up good and early then get out of the way and lend a hand with others.
Postby Magpie » Thu Aug 30, 2018 11:48 am
Jobs
  1. Gladiator - dash change out, corner weighting (no height adjustment), slight guard roll
  2. ManiacLachy - weighting and heights
Skills needed
  1. Guard rolling (there will be a guard roller and heat gun available)
CrazyRacer
Postby CrazyRacer » Thu Aug 30, 2018 11:55 am
How about an injector swap and initial MS3Pro PnP setup on my SE.
Not looking at anyone in particular ManiacLachy :lol:
Some guard rolling wouldn't go astray either if there's time.
Postby Magpie » Thu Aug 30, 2018 12:08 pm
Jobs
  3. CrazyRacer - injector swap, initial MS3Pro PnP setup (SE), guard roll
Skills needed
  2. MS3Pro PnP setup/initial tune
ManiacLachy
Postby ManiacLachy » Thu Aug 30, 2018 12:13 pm
CrazyRacer wrote:How about an injector swap and initial MS3Pro PnP setup on my SE.
We can probably do the MS. Make sure you have a wideband as well.
Injectors I've not done before, and while it would be doable, I'd suggest leaving the stocks in right now. Get the car running nicely then re-visit the injectors. The MS isn't quite as simple as plugging it in and turning it on, we'll have to do some fiddling and even at the end of the day it will not be perfect (but should be driveable).
CrazyRacer
Postby CrazyRacer » Thu Aug 30, 2018 12:28 pm
ManiacLachy wrote:We can probably do the MS. Make sure you have a wideband as well.
Sounds like a plan.
I have an Innovate wideband. I'd better make sure there's a suitable bung for it in the exhaust!
Guess I'll need to install the MAC valve for boost control too.
Only has to be able to drive onto the trailer at the end of the day (its an unregistered race car), but would be good if its a bit more driveable than just that.
Thanks
ManiacLachy
Postby ManiacLachy » Thu Aug 30, 2018 1:46 pm
Let's plan to keep it as stock as possible for this run. That way if things aren't playing nicely we can just plug the stock ECU back in. Yeah, check you have a bung in the exhaust for the WBO2.
JBT
Postby JBT » Thu Aug 30, 2018 3:38 pm
Can I spectate?
Postby Magpie » Thu Aug 30, 2018 4:23 pm
JBT wrote:Can I spectate?
Of course you can hinder, help, humor and or harass :) Chairs will be provided for spectators :)
JBT
Postby JBT » Thu Aug 30, 2018 4:51 pm
Jobs
Skills needed
Spectating, getting in the way, asking questions, helping
JBT - will bring a chair
Postby Lokiel » Thu Aug 30, 2018 5:41 pm
For injector swaps, read MSMjohn's thread: https://www.clubroadster.net/vb_forum/58-forced-induction/27215-mazdaspeed-mx5-denso-321cc-23250-74050-injector-info.html
- awesome IDIOT'S GUIDE (lots of pictures - I've used it all 3 times I changed my injectors)
Will be there to help and can cook up some smoked lamb unless anyone has any objections?
Gina may or may not be present depending on what I can get done in September (still have one project I want to FINISH otherwise it'll never get done).
I've booked a week off in October where I plan to install the TSE manifold and downpipe (will need to take the car to a muffler shop to modify Dann's 3" exhaust to fit), install NitroDann's engine mount while the exhast manifold is OFF, redo the hotside intercooler plumbing, modify the mixing manifold to simplify the lower radiator hose routing, redo the air intake and re-make the Cold Air Box. Once I start these jobs, Gina will be undriveable until they're complete so I wanted to wait until I had time to do it.
Maybe we could get all this done at the Dodgy Day???
Postby Magpie » Thu Aug 30, 2018 6:44 pm
Lokiel wrote:Maybe we could get all this done at the Dodgy Day???
You found my lamb hint :)
Remember what is not completed on dodgy day will be transported to the dam and ...
CrazyRacer
Postby CrazyRacer » Fri Aug 31, 2018 12:21 am
Do we need a popcorn maker too?
Postby Magpie » Fri Aug 31, 2018 5:45 am
CrazyRacer wrote:Do we need a popcorn maker too?
yes I have one...
Users browsing this forum: No registered users and 44 guests
