Hi everyone.
I'm looking for a recommendation for a Brisbane shop with a dyno that hires at a reasonable rate.
My situation is I'm looking to do a base line measure, then a few third or fourth gear pulls with the new tune installed to both compare and log to send the results back to the tuner for any changes.
Southside is preferable however I'm happy to travel around town for the right shop/ price.
Recommendation for Brisbane garage with dynomometer
- MikeVictor
ND GT with a loose nut behind wheel
Re: Recommendation for Brisbane garage with dynomometer
Hi MikeVictor,
I can recommend Gary Stewart 3273 3164 south side. He is a great bloke with many years experience with MX5s.
david
david
https://www.ianboettcherraceparts.com.au/advertising.php
Chassis Dyno Hire
The Dynapack, our incredible chassis dyno, has been described as our secret weapon on more than one occasion it’s what we use to squeeze every last drop of power from our engines.
As a chassis dyno, the Dynapack couples directly to the wheel hubs and applies a precisely controlled hydraulic load.
This method of direct coupling, combined with its built-in strength, results in a huge number of benefits over alternative methods, including better accuracy, enhanced control and sensitivity, and greater speed. In essence, it enables us to create near ‘laboratory conditions’ and to hunt down the very best results.
Print outs are provided of the power, torque, air fuel ratio and manifold pressure levels if applicable
Dyno hire
Engine Tuning
Power runs
Chassis Dyno Hire
Dyno hire
Engine Tuning
Power runs
- MikeVictor
Thanks guys.
