Page 1 of 2
1991 NA6
Posted: Sat Mar 18, 2017 4:12 pm
by glen73
Been awhile but I have another MX5. Picked up and straight onto club plates. I dropped the ride height to much but took a few pictures anyway. Will be doing sprint days so will see you around.
Re: 1991 NA6
Posted: Sun Mar 19, 2017 11:20 am
by 93_Clubman
Welcome back! Doesn't sound like you'll be turboing this one right away.
Re: 1991 NA6
Posted: Sun Mar 19, 2017 1:18 pm
by glen73
Cheers, no turbo plans as I want something I can compare lap times to. This car only has a mx5 plus roll bar and hsd coilovers. So will be good to ad stuff slowly to see how it effects lap times.
Re: 1991 NA6
Posted: Mon Apr 17, 2017 7:15 pm
by glen73
New mirrors today
Also picked up a 1.6 Vlsd. I hope I will be gentle enough and it will not break. Also did the foamectomy. Fitted a Beavis engine dampner and a cheap pod. Just a few more maintance things and will be ready for the track.
Re: 1991 NA6
Posted: Sun Jun 25, 2017 10:05 am
by glen73
Makes me look forward to spring and summer.
Re: 1991 NA6
Posted: Sun Jun 25, 2017 1:03 pm
by lucmor444
What mirrors are they? They look good.
Re: 1991 NA6
Posted: Sun Jun 25, 2017 7:43 pm
by glen73
Not sure, got them in a box of bits.
Re: 1991 NA6
Posted: Sat Jul 08, 2017 6:17 pm
by glen73
Had a sound like metal on metal over aggressive pot holes from right rear. Trying a few quick fixes of, softening the dampers and going from 195/55 to 205/60 (14"s) this helped and cushioned the ride but it was still there, just not as bad. So i decided to put her up on jacks and check over all the rear suspension starting with the shocks. Went to undo drivers side shock and noticed the bottom shock bolt was turning and there was no action. My first thought was a spinning nut but I could see the nut was still in place and not rotating. Next thought is either nut thread is mush or bolt thread is mush. After playing for a while it become apparent that this wasn't going to be a quick job. So I decided to drop the rear arm so I could work on it more comfortably on my bench First thing I noticed once free I could feel the shock had quite a lot of vertical slop. Possible cause of metal on metal sound.
I didn't want to go chasing a lower arm so I decided the nut and bolt were expendable and easier to post if bought over the net. I removed the side tabs of the nut and got to work.
With not a lot of operating room I drilled from the side
Starting with a small drill bit I worked my up
Until it split
You can see both the nut and bolt threads are gone, who ever fitted the coil overs must have gone nuts on the rattle gun when tightening up.
Now all I need is a new nut and bolt. If this helps anyone I'm happy.
Re: 1991 NA6
Posted: Sat Jul 08, 2017 7:28 pm
by NitroDann
I've seen that more than once.
Re: 1991 NA6
Posted: Sat Jul 08, 2017 9:07 pm
by lightyear
It's the right colour. Pity about the bolt. And that rollbar looks low. Bring it to P.I tomorrow, you can enter on the day. ;)
Re: 1991 NA6
Posted: Sun Jul 09, 2017 7:01 pm
by glen73
Got a new high tensile bolt from good ol bunnings.
Found it a little ironic you would put anti seize on and then mutilate everything :lol:
Re: 1991 NA6
Posted: Sat Dec 23, 2017 7:30 pm
by glen73
Cosmetic changes
new spoiler, Cobra seat straight to the floor and black window frame.
Re: 1991 NA6
Posted: Sat Dec 23, 2017 8:20 pm
by lucmor444
Nice - where did you get your spoiler?
Re: 1991 NA6
Posted: Sun Dec 24, 2017 9:57 am
by glen73
lucmor444 wrote:Nice - where did you get your spoiler?
I got this one, https://www.ebay.com.au/itm/For-90-97-M ... 25b&_uhb=1
Re: 1991 NA6
Posted: Sun Dec 24, 2017 12:08 pm
by trader
Interesting.....modded car on historic plates. Didn't think I could do that. But then I'm in the nanny state!
