Kevlar Hose Failure
Posted: Wed Dec 28, 2016 8:24 am
BEWARE!!
Five years ago I replaced the coolest water hose in my 1993 MX-5 NA8 system with a Kevlar hose and today I found it has split. The hose I speak of is the one from the bottom hose metal extension to the water pump. The origin Mazda hose was not leaking but was replaced as a precaution because I changed the leaking water pump which was 18 years old. Now I intend to replace the failed Kevlar hose with a genuine hose and probably not worry about it for another 18 years. My car is a standard un-turboed, so the hose was under no extra pressure. Maybe someone on the forum can explain the failure.
