BEWARE!!
Five years ago I replaced the coolest water hose in my 1993 MX-5 NA8 system with a Kevlar hose and today I found it has split. The hose I speak of is the one from the bottom hose metal extension to the water pump. The origin Mazda hose was not leaking but was replaced as a precaution because I changed the leaking water pump which was 18 years old. Now I intend to replace the failed Kevlar hose with a genuine hose and probably not worry about it for another 18 years. My car is a standard un-turboed, so the hose was under no extra pressure. Maybe someone on the forum can explain the failure.
Kevlar Hose Failure
- NitroDann
Re: Kevlar Hose Failure
Probably just not great quality control at the kevlar hose factory.
Any chance of a photo of the failed part?
Anything man made will break. Thats the explanation.
Never put the top up unless the storm has a name.
Here is the split, hose came from Autolink UK.
Thought you sold the NA8 earlier this year, but then think you had two.
Had 2 now have one.
I put the same kevlar hoses on my car at the same time. Earlier this year the lower radiator hose broke - not split or cracked or burst, just became totally brittle and broke like a piece of cheap plastic. It cost me a cylinder head. Not happy at all. It's the least stressed hose in the whole cooling system. I've ripped all the rest out and put in genuine Mazda hoses from Amayama.
