Engine ID location
Tigger
Engine ID location
Postby Tigger » Sat Aug 13, 2016 8:29 pm
Hi all. I have a 2003 NB, and Repco have given me a valve cover gasket for it.
However, it doesn't fit. The two 'moons' behind the cam gears are the same size, suggesting non svt.
Sooooo, I'm trying to find what engine I have. I can't locate the engine ID on it. I believe it's on the rear of the block on the passenger side, but can't find it.
I thought it was a BP-ZE, but on the throttle body it says BP-4W.
So I'm a little confused.
Any help?
smy0003
Re: Engine ID location
Postby smy0003 » Sat Aug 13, 2016 9:35 pm
Look up the part number through the Gates website or similar, and ask them for that specifically.
Repco and co. have trouble supplying correct parts a lot of the time.
Your engine is VVT, but small bits and pieces may be shared between the many iterations of the BP engine.
[b]Then: Sunlight Silver NB8B
Now: Chaste White NA8
Tigger
Postby Tigger » Sat Aug 13, 2016 9:38 pm
Thanks. I tried that, but with no luck. I know the se used the BP-4W, which is why I was more interested in that side of it.
I might get one from elsewhere as I'm having no luck with them.
Postby 93_Clubman » Sun Aug 14, 2016 11:01 am
Tigger wrote:I can't locate the engine ID on it. I believe it's on the rear of the block on the passenger side, but can't find it.
As smy mentioned the 2003 should have the VVT motor, which appeared here in the NB8B from Oct 2000. Toward the rear of the block on the passenger side almost under the exhaust manifold is the engine number, which should start with BP followed by numbers. On the back of the head there's also a head identifier: NA8: BP05; NB8A: BP4W; NB8B & NB8C: BP6D.
Tigger
Postby Tigger » Sun Aug 14, 2016 11:21 am
Thanks for that. I'm not that keen on going under the exhaust manifold lol.
I know which model I have, and it is the SVT, I am more interested in the engine code. Ie BP-ZE/3, BP-4W etc.
I might just get one from somewhere else that isn't a store like that.
and1
Postby and1 » Sun Aug 14, 2016 2:24 pm
BP-4W is the NB8A and SE head. Non VVT.
BP-Z3 I think is the code you're after.
2005 Velocity Red MX-5 SE
Garage thread
Tigger
Postby Tigger » Sun Aug 14, 2016 3:29 pm
That's what I suspected. Thanks very much. :D
