Having issue replacing tyres
tjongster
Postby tjongster » Sun Dec 06, 2015 5:48 pm
Hey guys new here sorry if this sounds newb
I am in the midst of changing my tires and it seems the tires i bought the usually spanner or L tool to remove the original mazda wheels are too big to fit
My wheels are rpta rbx15x7 +25s
Any help will be greatly appreciated
Sent from my SM-N910G using Tapatalk
Re: Having issue replacing tyres
Postby hks_kansei » Sun Dec 06, 2015 6:19 pm
Similar issue with my ms03 wheels.
Options are
longer wheelnuts
Thinner wheelnuts
Thinner socket.
I originally used a spark plug socket that I ground the outside down, but then bought some thinner wheelnuts so I could use a regular socket (current nuts are 19mm 949 racing vs the 21mm stock ones)
tjongster
Postby tjongster » Sun Dec 06, 2015 6:28 pm
Any sites i can get these thinner wheel nuts from ? Or those super cheap stock them ?
Postby hks_kansei » Sun Dec 06, 2015 8:17 pm
I got mine from a group buy ages ago.
Super cheap stock nuts but never looked at them in detail to see what kinds
The American
Postby The American » Sun Dec 06, 2015 8:23 pm
Have you tried a basic socket instead of the wheel brace? You might find one of those to be slim enough to do the job.
tjongster
Postby tjongster » Sun Dec 06, 2015 9:01 pm
sorry the american ! what dya mean by a socket instead of the wheel brace ?
The American
Postby The American » Sun Dec 06, 2015 9:15 pm
I mean one of these - you might find with a quality socket the wall is thinner and may be more able to access the space you have:
you should be able to by them individually from an auto parts store
The American
Postby The American » Sun Dec 06, 2015 9:17 pm
I just had a second look at your photo - you might indeed need to go the sparkplug socket or longer wheel nuts route (s)
MXO005
Postby MXO005 » Sun Dec 06, 2015 9:20 pm
I ended up buying these:
https://www.tradetools.com/product-rang ... -17mm-19mm
Trade Tools actually sold the 19mm I needed individually.
Still needed to remove the plastic/protective cover to get on a couple of nuts.
https://www.tradetools.com/product-rang ... wivel-head
Ian
Silver '94 Eunos Roadster - Nothing much to report.... yet!
Postby hks_kansei » Mon Dec 07, 2015 10:32 am
Just a warning to people buying the long armed breaker bar/socket handle.
when tightening the nuts DONT just rip on the handle as tight as you can. It's a good way to snap a stud, or strip a nut.
it wont feel like it, but there's a lot more leverage on those handles than the X shaped wheel brace, or the factory wheel brace. (and you don't need to super tighten with them either)
Postby Lokiel » Mon Dec 07, 2015 11:22 am
hks_kansei wrote:Just a warning to people buying the long armed breaker bar/socket handle.
That's good advice but it's also useful to get an actual feel for how tight they need to be and the only way to know this is using a torque wrench in conjunction with your tool of choice.
When I bought my 6ULs I also purchased the aluminium lug nuts which had warnings against over-tightening so I purchased a torque wrench to ensure I didn't do this.
After installing the wheels the first time I was shocked when I realised that for years I'd been over-tightening my lug nuts - usually by tightening the lug nuts firmly by hand, then giving the bar a couple of presses with my foot - lucky they were steel!
