CarMakeRevive- SR20 6speed tube drift mx5
Revive mx5
Postby Revive mx5 » Sat Sep 05, 2015 2:19 pm
Ok, I haven't got an enormous amount of time to document this build as the car has to be finished by Jan 1st 2016, so
Plan for the build
- weight to be kept to a minimum
- 90's era drift styling, see BN SPORTS Fc Rx7, 326 Power, etc
- very low
THE BITS AND PIECES
DRIVELINE
- sr20det engine- 256/264 HKS cams, tomei cam gears, raised compression, Td05-18g turbo, ID 1000cc injectors, etc etc
- OS Giken twin plate
- 350z 6speed with my custom bell housing and shifter
- driveline services tailshft
- Nissan R200 4.3 diff, hi volume cover, locked centre
- Nissan s15 rear end geometry
- s13 Power FC Dejectro (no AFM)
FRONT END
- Toyota Ae86 front fully adjustable base adjustable struts
- FD Rx7 calipers, Wilwood sprint car full floating disks, my own custom alloy hats
- sprint car torsion bar sway bar
- mx5 steering rack
- Toyota Echo EPS (electric power steering), with aftermarket controller
- custom steering arms, control arms and tension arms
REAR END
- full adjustable struts (all alloy- light weight)
- sprint car torsion sway bar
- all adjustable rear arms
BODY
- tube frame front and rear, integral roll cage
- tubed rear (height)
- raised gearbox tunnel to fit big ass 6speed
- 20mm ride height
- motor moved rear wards about 250mm
- full Arios body kit
- big steel arches
- hardtop solid mounted, Lexan rear screen
- stripped and gutted doors
- and other stuff
WHEELS
- Epilon Southernway mesh 15" x 10" fronts, 195/50/15
- Epilon Southernway mesh 15" x 11" rears, 205/50/15 (3x pairs)
- SSR MKll 15" x 10" fronts
- SSR MKll 15" x 11" rears (3x pairs)
My old car
Revive mx5
Re: CarMakeRevive- SR20 6speed tube drift mx5
Postby Revive mx5 » Sat Sep 05, 2015 2:23 pm
Rear wheels
New seats awaiting shipping from Japan
Revive mx5
Postby Revive mx5 » Sat Sep 05, 2015 2:26 pm
Sitting on chassis jig
Dummy motor fitted
Revive mx5
Postby Revive mx5 » Sat Sep 05, 2015 2:38 pm
Some welds not the best, my old welder decided to pack it in, was a good excus to buy a new BOC inverter 275amp, yewwwwwwww
Revive mx5
Postby Revive mx5 » Sat Sep 05, 2015 2:43 pm
Rapped tail lights
Z33 (350z) 6speed with my fabricated bell housing
Revive mx5
Postby Revive mx5 » Sat Sep 05, 2015 2:55 pm
The dash so far
Revive mx5
Postby Revive mx5 » Sat Sep 05, 2015 3:03 pm
Some guards I built a couple of months back for a mates LS1 corona wagon with 11" rears
DanZig
Postby DanZig » Sat Sep 05, 2015 3:19 pm
Bloody serious build right there. Keep it up looking great!
That 86 is stunning. Have any info on that build?
mrpham
Postby mrpham » Mon Sep 07, 2015 12:29 am
This is awesome!
Current Forum Specials!
Revive mx5
Postby Revive mx5 » Mon Sep 07, 2015 1:59 am
DanZig wrote:Bloody serious build right there. Keep it up looking great!
Purple AE86
- motor- s14 SR20det, cams, gears, injectors, HKS turbo
- power fc ecu
- os twin plate clutch
- R32 skyline gearbox
- tarago diff 4.3 locked
- s13 front coil overs
- custom trd rear coil overs
Etc etc
I have the magazine article somewhere, would probably be easier to scan it, the 86 was great but made way for my house
JZP
Postby JZP » Mon Sep 07, 2015 1:41 pm
Naice...
Likey likey a lot
beavis
Postby beavis » Mon Sep 07, 2015 1:53 pm
im just sittin' here watching....
speed
Postby speed » Mon Sep 07, 2015 2:16 pm
Wow, subscribed! :)
WTAC next year?
kazama
Postby kazama » Mon Sep 07, 2015 2:24 pm
Holy smokes, now this is a serious build WOW
Zabinskii
Postby Zabinskii » Mon Sep 07, 2015 2:39 pm
hahah its come a long was since i last saw it when i picked up the rear bumper and radiator ;)
Users browsing this forum: No registered users and 73 guests
