I am in the process of purchasing a 1990 Miata for my drift build this winter and I was wondering if anyone had any input on it
Names Marissa!
Regie wrote:Gday Marissa.
Wazman (Warren) down in victoria has a NB drift car, he could probably give you some tips
hks_kansei wrote:PM via the forum is probably best.
For drifting (although I havent done it) generally you want to have an LSD and fairly stiff suspension.
And ideally, some power so it's easy to break traction and slide.
Have you done any drifting or similar before?
If not I'd suggest it's best to do some first, skidpan days etc, to get a feel for the car as it is. Once you've got some practice with a basic car you will be more able to understand what it is you need/want to do with it to suit you.
Jeo wrote:So, you're in the US then?
marissaleefunk wrote:Jeo wrote:So, you're in the US then?
Canada actually
rascal wrote:Apologies for the insult then..![]()
Jeo wrote:rascal wrote:Apologies for the insult then..![]()
My bad!
Ignore the build. Fix anything that needs fixing. Go drive and change things as you find specific problems.
kalt wrote:I understand the general rule of thumb with drifting is:
"the greater the horsepower your vehicle has, the less importance is placed on driving skill"
So... budget according to your driving skill, maybe?
rascal wrote:marissaleefunk wrote:Jeo wrote:So, you're in the US then?
Canada actually
You'd probably be better off looking at http://www.miataturbo.net/
A nat asp mx5 wont make much of a drift car..
