OaKiecOpTeR's NA6 - Road to Hillclimb
OaKiecOpTeR
Postby OaKiecOpTeR » Mon Dec 29, 2014 8:13 pm
So I've been "playing" cars for a few years now... I've come from a Nissan background (250kW '97 Midnight Purple 180SX TYPE X), but figured it's time for a sea change.
The MX-5 bug bit about a year and a half ago when I stumbled upon Danny's Engineering-porn 20B NC, and 'OmgPham.com' NA6 build. So finally the right project car came up for me and suited my budget. I have a few plans for the car so stay posted.
21/12/14
The new project - Aussie Delivered '90 Limited Edition BRG NA6
27/12/14
Having owned the car for a week now I'm beginning to see that raw power isn't needed to have fun when you have in essence a road-registered go-kart.
Shedding a few kg (planning to remove all A/C and heater core, coolant heater core bypass)
28/12/14
All gone:
greenltd
Re: OaKiecOpTeR's NA6 - Road to Hillclimb
Postby greenltd » Mon Dec 29, 2014 9:01 pm
Aaahhh my car. You weren't wrong when you said you were going to lighten it. Glad you made it home and are enjoying your new ride. Good luck with your project, I'll be watching with interest. Stephen.
The American
Postby The American » Tue Dec 30, 2014 6:57 am
Welcome!
Think twice about removing the heater core. It is required for road worthy, and handy for demister duties (on and off the track).
OaKiecOpTeR
Postby OaKiecOpTeR » Tue Dec 30, 2014 9:53 am
The American wrote:Welcome!
Already done, luckily for me in Adelaide we don't have an annual 'road worthy,' it's only required to pass defect (as previous experience with my brother's S13 showed us), plus I'm intending on installing an electric heater/Demister setup or failing that a twin hair dryer setup :P
OaKiecOpTeR
Postby OaKiecOpTeR » Sat Jan 03, 2015 5:15 pm
3/1/15
The hills are on fire! last night I was getting a emergency evacuation messages... Started packing a few bags ready to go just incase.
In the early hours of the morning (3.30AM) I decided I wasn't going to sleep anyways and started to make an attempt to get the mx5 running again ready to bug out, worst case scenario. Unfortunately I'll have to pull it apart again as I hadn't gotten around to doing the painting I wanted to...
3:30AM
5:30AM - Quickest dash "install" (unfixed), temporarily bolted/ cable tied in steering column, coolant flush and fill (tried to cut some corners doing the heater bypass and attempted to do it without dropping all of the coolant - lost about a litre and a half. Did this as I'd planned to change all the fluids after I'd finished stripping the car before driving her again), seats installed, reconnected the wiring harness.
Decided to go with the safer option and head to the parent's house... At this stage the fire is about a 5km away from home but thankfully the erratic winds have decided to head the other direction.
Also, my brother lathed me up a nice gear knob for my Chrissy present, unknowingly though he tapped an M10 x 1.50 thread into it... Will have to see if he can retap it to 1.25.
track_addict
Postby track_addict » Sat Jan 03, 2015 6:55 pm
I'll be following this build for sure. I've got a soft spot for BRG NA's! Will be good to have another mx5 out at the hillclimbs with us. Usually only have 2 or 3 of us. If you ever need a hand, let me know!
89' Roadster - Sold
'04 SE - Sunlight Silver.
Postby Okibi » Sun Jan 04, 2015 12:34 am
if you're going full light weight and you've removed the heater, consider something like this
OaKiecOpTeR
Postby OaKiecOpTeR » Fri Jan 09, 2015 8:28 pm
So I've been purchasing a few items lately, some of which had started turning up.
MX5 Plus offset bracket:
42 Draft Designs Ultimate Catch Can:
Benen Neochrome Front and Rear Tow hook set:
(Which I intend on drilling to replace the OEM tow hooks.
When the heat becomes a little more bearable (my garage is horrible at the moment) I'll get on installing/mounting these bits and pieces...
OaKiecOpTeR
Postby OaKiecOpTeR » Wed Jan 14, 2015 8:49 pm
Some more progress.
Tow hooks installed - fixed the rear one in a way that it wouldn't stick out as it still my daily driver for the moment.
Restoring/ Paint rain rails and panels
Working on replacing my door cards - aluminium
Also found an mx5 (eunos) buddy today
OaKiecOpTeR
Postby OaKiecOpTeR » Sat Jan 17, 2015 3:23 am
Today I spent most of the day cleaning up the little mx. I wasn't all that impressed with how the doors were looking so I decided to attack the sikaflex type adhesive silicone with a razor blade and wax and grease remover.
Then I hit them with some leftover paint
Next up on the agenda was a decent service
Tomorrow morning I'm going to reconnect some of the lesser important components of the wiring harness and get the dash in properly, as me and the mx have a date we need to impress :P
Unfortunately when your other car is missing a few vital components (budget restraints) and your mx is in the process of having its interior somewhat restored/changed/removed, I don't really have any other options :)
Postby Magpie » Sat Jan 17, 2015 6:43 am
The quickest way to remove the black goo is with a heat gun, get it hit enough and it wipes off. No damage to the paint below, however the hot black goo will burn your skin so wear decent gloves and have a good supply of rags.
OaKiecOpTeR
Postby OaKiecOpTeR » Sat Jan 17, 2015 6:29 pm
Magpie wrote:The quickest way to remove the black goo is with a heat gun, get it hit enough and it wipes off. No damage to the paint below, however the hot black goo will burn your skin so wear decent gloves and have a good supply of rags.
Cheers, I'll keep that in mind... Unfortunately/fortunately I think that's the last of the tidying up I'm doing at this stage.
Next thing on the cards: I'm organising with one of my brother's best mates whose an auto electrician to install a "super-awesome" alarm and central locking kit.
OaKiecOpTeR
Postby OaKiecOpTeR » Sun Feb 08, 2015 4:59 pm
Alarm +central locking kit is in. Stripped out about 1kg worth of existing wiring, and also tidied it up a little.
Also, finished up my door cards
Still waiting for a few goodies in the mail - hopefully they turn up this week.
