Increasing rev limiter On NC model
Novice1
Postby Novice1 » Sat Jun 07, 2014 6:23 pm
My 2006 NC is going for a tune on tuesday at chip torque.
Just had MX5 plus extractors and muff,er fitted. Idle is a little low at present..
I have the option of having the rev limiter increased.
I am oen to pros and cons of this approach.
Advice welcome.
Novice1 aka Ron
Re: Increasing rev limiter On NC model
Postby Regie » Sat Jun 07, 2014 8:27 pm
Ice increased my limiter to 7500rpm.
Then again I've never hit the limiter. No real advantage increasing it. May as we'll keep it at 7200rpm.
I'm going to get my limiter reduced when I upgrade to the racerom flash
sailaholic
Postby sailaholic » Sat Jun 07, 2014 8:46 pm
No point of it doesn't make power there.
16bit
Vehicle: NB8A - Supercharged
Postby 16bit » Sun Jun 08, 2014 10:07 am
only reason if you are not making extra power up there would be to hold onto a certain gear at certain race tracks.
other then that its just increased unnecessary wear and tear.
Novice1
Postby Novice1 » Sun Jun 08, 2014 12:42 pm
Thanks fo the replies. I will keep rev limit as it is.
Cheers Novice1
