NitroDann's ultimate street NB
- NitroDann
I am starting an NB in a week, which I would probably consider to be damned close to the ultimate version of a gentlemans sensible road car. NitroDann's SP if you will. It is a gorgeous almost immaculate NB8C setup so be the ultimate sensible weekender/daily. It belongs to a man who test drives the latest cars for a living, and everything must be gorgeous. It will use the fewest components possible, and of them, only the best.
It currently has BC external reservoir coilovers, and some nice wheels and tyres with an excellent alignment, I have pulled the engine out and inspected everything, it has brand new mounts, an OEM SE clutch, and a gorgeously tuned, better than factory driveability Haltech Platinum Sport 1000, along with a 2.5" stainless exhaust, with mufflers I chose specifically to keep it sensible yet sporty.
On the way is a brand new genuine GT2560r turbo, the same as the SP, 10mm Inconel studs and Stage 8 locking hardware, the Haltech genuine electronic boost solenoid to get silky smooth delivery of torque, and a Turbosmart Kompact 34mm BOV. It will most likely utilise a laser cut CNC bent airbox, and everything will be made from 304 or 316 SS like usual.
Pics to follow.
Pics to follow.
- 16bit
Re: NitroDann's ultimate street NB
what sort of manifold are you going to do, log or one of your fancy equal length jobs?
- speed freak
Interested...
Definitely going to be following this thread
Keen to see how this will drive after its done.
Ken.
Ken.
This will be something to keep an eye on!
- tescoking
cool, this should be my first garage chat that i could see from the very beginning
Looking forward for the build!
Maybe ill grab some pointers from this build for my nb8c turbo plans. ;)
Good luck!
Good luck!
- bruce
- Vehicle: NA8 - Turbo
- NitroDann
You read it here first ! Gorgeous like Simons manifold, like Yemins tune.
Sounds pretty much the exact same as my setup
Sent from my HTC_PN071 using Tapatalk
- NitroDann
Low mount, like a factory SE or something... but way better.
Decided I didnt like the wastegate action using the divorced flange I had so I made a better one, not bad for a grinder and a file?
Get on my facebook and check the comments and see more details
Looks great Dann!
- Vehicle: ND - Turbo
- taminga16
Dann,
Your welds are looking more and more like babies tears every day.
Greg.
Greg.
