MX5 - Weekender & Slight Stance build
thelaughingman
Postby thelaughingman » Wed Oct 23, 2013 9:09 pm
Hey CT,
So i just purchased my first MX5 i've pretty much owned as many cars as I've had birthdays (the MX5 is #26) basically over the years I've been trying to learn more about cars and find what suits me best. I ahd never dríven one before and after taking one for a spin with a CAI, extractors, Full exhaust system and coil-overs i was hooked. However im terrible with body work so i wanted to find the one with the best paint that i could. Coming from a Honda background i was steering clear from red cars as i believe the reds used in the 90's Japanese cars just end up fading and i already will be driving a MX5 so no need to have a pink one too.
i had a look at some more cars but they were either badly maintained or the body work wasn't up to par or the seller wanted too much.
i eventually came across a 1990 NA6 in Mariner Blue.
Pros:
- Rego until April '14
- Full service history since 1990
- New tyres
- New soft top
- Complete Momo steering wheel with crash pad
- Stock intake, exhaust, suspension etc..
Cons:
- RHF guard is dented
- Bonnet has light hail damage
- Boot lid slightly different colour (hail damage again)
- LHS Window reg stuck
- Noisey gearbox bearings
- RHR caliper leaks (seal kit was done 4 months ago so taking back to mechanic to get replaced under warrenty)
- RHR wheel bearing nosiey
- RHF tie rod end cracked
Needless to say after the first drive i wanted this car even stock it handled so well so i made an offer on the spot and 4 days later took it home.
Pictures and more updates to follow shortly :)
meanmx
Re: MX5 - Weekender & Slight Stance build
Postby meanmx » Wed Oct 23, 2013 10:52 pm
Awesome. You should think about coming to one of our Thursday night meets. Check in the vic section for up to date info.
2014 VW Mk7 Golf R
M1474
Vehicle: ND - Turbo
Postby M1474 » Thu Oct 24, 2013 12:36 am
Congratulations!
Mazda red paint is the best red paint I've come across. (Not that that matters fir you.)
Sounds like a re spray of bonnet, boot and fender unless you can learn to live with it as is.
Although f you do your body work on a 40deg day in the sun you can sometimes knock out dents without cracking paint.
A mate has hail damage we are going to try to repair with a refrigeration vac pump, I'll let you know if it works.
GHETTOCET
16bit
Vehicle: NB8A - Supercharged
Postby 16bit » Thu Oct 24, 2013 8:10 am
thelaughingman
Postby thelaughingman » Thu Oct 24, 2013 8:15 am
meanmx wrote:Awesome. You should think about coming to one of our Thursday night meets. Check in the vic section for up to date info.
Ah cheers i'll keep that in mind thanks!
M1474 wrote:Congratulations!
The boot and bonnet im thinking maybe ill go carbon so i'll live with it for the moment, the guard really annoys me so i'll take it to a couple panel shops and see what the cost will be to repair it.
16bit wrote:Image
Wow the troll is strong with this one
16bit
Postby 16bit » Thu Oct 24, 2013 8:18 am
haha, yes.
any plans for first mods or you going to just live with it for a while and decide?
thelaughingman
Postby thelaughingman » Thu Oct 24, 2013 10:37 am
16bit wrote:haha, yes.
Yep already have added some stuff to it.
Mods So far:
- ARC Intake Chamber
- KG Works Type I Roll Bar & Harness Bar
- MK2R 14x6 Wheels - waiting on tyres (I have them for sale but if they dont sell will be my every day wheels)
Ordered:
- TSI's (thanks to a MX5CT Group buy)
- Alloy Radiator
- 3pt Front Strut Brace With BMS
- BC BR Coilovers
- Fujtisubo 4-1 Extractors
Plans:
Interior:
- Fixed seats
- Different gear knob
- Better head unit & Speakers
- Oil temp, Oil Pressure & Water Temp gauges
I aslo have a wideband LC-1 Gauge but dont think thee is any point in fitting it.
Engine:
- High flow cat
- Cat back exhaust (hoping to get a fujitsubo to match the headers)
- CAI
- Silicone hoses
- Oil filter relocation & maybe oil cooler (but i don't think its needed unless i hit the track)
- alloy overflow tank & washer tank
- Carbon Bits
- Plug leads (mine need doing anyway)
then a general tidy and replace things as required
Exterior:
- Carbon front lip
- Carbon bonnet
- Carbon headlamp covers (Lh vented Rh not)
- Carbon bood lid with tail
- Carbon hardtop (i can dream cant i haha)
- Carbon side skirts
- Benen tow hooks
- Sleepy eye conversion with square headlamps and HIDs
- offset number plate
Suspension & Drive line & Brakes
- Rear strut brace
- Front and rear swaybars
- Adjustable camber arms
- LCA brace
- LSD (unsure what though)
- Better rotors & pads
Wheels:
- Work Miester SP1s 14x7.5 & 14x8.5
Im sure this will change constantly
Thats off the top of my head
M1474
Vehicle: ND - Turbo
Postby M1474 » Thu Oct 24, 2013 11:51 am
thelaughingman wrote:Exterior:
- Carbon front lip
Buy them in bulk, they will splinter into little peices.
I'm not even low and my lip scrapes the ground on the daily.
GHETTOCET
thelaughingman
Postby thelaughingman » Thu Oct 24, 2013 5:59 pm
- Carbon front lip
really how bad? (link to a pic if possible)
M1474
Vehicle: ND - Turbo
Postby M1474 » Thu Oct 24, 2013 6:28 pm
Honestly I've never had a cf front lip before but I have plenty of smashed cf model helicopter parts. Pics of my front lip touching the ground? I'll see what I can do.
GHETTOCET
thelaughingman
Postby thelaughingman » Mon Oct 28, 2013 3:39 pm
UPDATED:
So I got a couple new parts on the weekend.
- 3pt Mazdaspeed front strut brace with BMS
- Custom Side exit exhaust
- BC BR Coilovers
So Saturday was productive, i went to work and replaced the Oil, Oil filter, Rocker cover gasket, Spark plus and rear wheel bearing and i also installed the front strutbrace, i've yet to install the plate the joins it to the upper scuttle panel but that will get done this week when i get a drill.
Sunday however was not as productive as i had hop[ed it would be, I attempted to install the side exit exhaust had the old exhaust removed and when i went to fit it i noticed the flange to join my exhaust to the side pipe is different and so it couldn't' be installed and as there was no exhaust shops open i gave up and put the stock exhaust back on.
This week the plan is to get my coilovers in, tie rod ends replaced, wheels and tyres fitted (MK2R's) Alignment and maybe buy some more parts.
But most importantly take some good photos!
Users browsing this forum: No registered users and 243 guests
