Since then Ive installed yellow speed coil overs, AGI half cage, 949 6UL's 15x7.5's with 205/50/15 ku31's. Sparco Sprint V, 4-Point Sabelt Harness, 330mm Momo Corse steering wheel.
Ive been stocking up parts for a reliable and capable track toy which should be completed in a few weeks in preparation for the July 15th track day at lakeside.
the parts include;
2.5" Exhaust, V-band Dump pipe, Log Manifold, T28 Turbo - By Nitrodann
Cooling pro FMIC with stainless piping also fabbed by Nitrodann
DIYMS2, IAT and EBC solenoid
Xtreme HD Clutch
Lightweight Chromoly flywheel
Innovate AFR and Wideband 02
Turbosmart Dual Plumbed back BOV 25mm outlet
RX8 Injectors 450cc
Na8 1.8 3.9 Ratio, Kaaz 1.5 way, already regretting the taller gear ratio
Nb8a brake kit
52mm ASI Radiator
Coolant Re-route
Flyin miata Inconel bolts and fasteners
19 row Oil Cooler and adapter plate
Mazdaspeed Motor mounts
6UL 15x7.5
205-50-15 Khumo KU31
Coil on plugs
FM Dual feed fuel rail
SAAS Oil/Water Temp, Boost
DIY Oil Catch can
Energy suspension bushings Front and rear control arms
Mazdaspeed diff bushings
the B6 motor will be staying stock and looking to run about 7-10psi and stoked to start getting tonnes of track time! Radiator ducting and aero will be done once turbo is complete and I've attained some driving skill.
Been working my ass off while studying for the past year to get to where i am, moneys been focused on parts to go faster, hence you will all see why my car looks the way it does. Also I'm on a student budget, I've planned to paint it dark blue using International Toplac Marine paint using a roller haha. I know what all of you must be saying- this dude is on crack.
If you've read about people using marine paint to do full resprays under $50 bucks then you'll know what I'm on about
Sorry for the lack of photos, there isn't much to look at, but maybe tomorrow ill show you my nasty thing that i call my baby
Not really sure where this is going now, I'm the worst at telling a story maybe its because I'm asian, who knows!!
