Lightyears Red NA8B track car.
Posted: Wed Jun 19, 2013 9:13 pm
The c.f car thread has been taken over by this car. So I thought I would separate them. I talked to tyrone and it looks like the engine for the c.f car may be getting dynoed in the next month. So there may be progress on it again.
1991 NA6 body wrapped around 2001 NB8B everything.
So it has the following bits -
Standard 130,000km NB8B Motor, ecu and 6 speed box with lightweight flywheel and H.D clutch. Mazdaspeed engine mounts. $300 eBay extractors, and straight through exhaust with $90 offset in-out muffler.
Standard intake and paper Ryco filter.
Standard Torsen 4.3 diff out of ???
Standard NB8B ABS brakes, with carbotech pads, RBF660 fluid and braided brake lines.
Standard (ish) 15x9 6ul wheels and 225 nittos.
Standard NB8B fuel lines, filter and pump and full wiring loom.
Standard rubber bushes on standard suspension. Mixture of NB and NA. With a set of B.C Coilovers I bought second hand for $600. A white line front swaybar, standard NB rear.
Standard NA manual steering rack. With NB8B column and NA MOMO steering wheel on quick release hub.
Inside there is a Velo race seat, harness, cobra race seat for brave passengers, NB8B dash, console and carpets. And a 3 point rollbar. It has the full interior as well as the heater core/fan, etc. As per modified class rules. The only real luxury is the power windows.
NB8B elec boot release working of key remote. Must have for quick shock settings.
Standard hardtop.
G.V boot lid spoiler, and modified G.V front spoiler (part carbon fibre, part expander foam and part teruo fibreglass).
It's not an overly powerful car, but it's fun to drive. And handles well except for the oversteer. Hopefully can set it up a bit better.
It is always very reliable and competitive. I just put fuel in it normally. Never uses oil, and runs/starts just like a standard car.
I just do regular services on it. And I am sure it will last a long time.
Only problem is I have a complete built turbo motor with everything except the ecu sitting here waiting to go into a car.....
Standard hardtop.
