So after deciding to keep it and seeing how i go for cash after i get back from japan in dec, i decided i should waste some of my travel money on it. But first heres my other car which is where most of my money has gone.
95 180sx
Engine Mods:
Engine has two tunes - 261.2 RWKW on 18psi - But is only running the newer tune of 232rwkw
sr20det - refreshed at 115xxxkms
Full 3inch exhaust w/ Catco highflow cat and Kakimoto Cat Back - made better by nathan @ fabulous fab
IHI (apexi) rx6 tcw15 p18 turbo
trust 44mm type S gate and screamer
custom PowerTune high mount steam pipe manifold - HPC coated - lifetime warranty
custom stainless intake pipe
DE cams
GkTech rocker arm stoppers
greddy oil catch can
heavy duty clutch
short shift kit
bosch 040
haltech e8 with boost solenoid
sard fpr
Billet fuel rail and Rochester 860cc injectors
greddy copy inlet manifold
Hyrbid Front mount with custom stainless piping
greddy oil cooler and relo kit
BA Fans
Saber rad
Nismo Thermostat
ARC sump
Stainless Rad Over flow bottle and breather bottle
GKtech Bash Plate
Suspension/Wheels/Brakes:
Front:
17x9+22 AVS 5's and 18x9+20 AVS 5 which are currently on
215/45/17 Federal Evo's/ 215/35/18 595's
Carbing strut brace w/ BMS
BC Racing coilovers (8)
SPL PRO outer tie rod end set
Tein z33 inner tie rod set
SPL PRO tension rods v3
SPL Braided teflon brake lines
SPL Braided teflon clutch line
solid steering spacer
Whiteline Sway bar
S14 LCA's/knuckle/hub
R34 Front caliper
R34 slotted rotors
Rear:
18x10 +19 AVS 5
235/40/18 Federal 595's
Non hicas rear cradle - foam filled
Cusco strut brace
BC racing coilovers with GTR base (6)
SPL PRO rear toe arm set v3
SPL PRO rear upper arm set v3
SPL PRO rear traction arm set v3
SPL PRO solid subframe bushing set
R32 GTR diff
R32 GTR knuckles (alloy)
R32 GTR half shafts
R32 GTR caliper
Project Mu handbrake shoes
Slotted rear rotors
SPL solid diff mounts
Whiteline adjustable sway bar
Interior:
Cusco safety 21 5 point half cage
Recaro drivers and passenger seat
greddy TT
Personal steering wheel
HKS DB Chrono gauges - Boost, Water Temp, Oil Temp, Oil Pressure
JVC head unit and pioneer speakers
working A/C etc
Exterior:
Genuine type x front bar and indicators and lip
type x rear lights with carbon center
Genuine Bomex skirts
Genuine Gp-sports rear bar
flared rear guards
326 Power roof lip
326 Power boot lip
GP sports mirrors
How it started life:
And now:
