It all started for me when I went looking for a AH Sprite or MG Midget to do motorkhanas and some track days in, and couldnt find a solution that met my needs as ready to go fast and street regoed. I frequented My105 and carsales looking for that perfect bit of something and stumbled across this
The guy selling (demon on here) was a top bloke and spent heaps getting the car circuit ready, and after a 2 minute lap of his block, I knew it was the car for me. Heres a copy and paste of the spec sheet as per his ad;
Make/Model: 1990 Eunos Roadster
ODO: 161,000kms
Colour: Red
Engine: 1.6 litre, 4 cylinder
Trans: 5 speed manual
Factory Options
- Air/con (removed but have all parts)
- power steering (removed but have most parts)
- Roadster scuff plates
- comes with soft top and hard top
- 4.3 LSD
Modifications
Engine/Power/Drivetrain
- TD04L hi-mount turbo (water and oil cooled)
- Custom made steam pipe turbo manifold
- 3 inch exhaust from turbo back + metal hi-flow cat
- larger injectors
- Bosch fuel pump
- Pod Air filter
- Front mount intercooler
- 2 litre oil catch can
- Cooling Pro 52mm radiator
- Adaptronic ECU
- Turbo smart bleed valve
- Excedy heavy duty clutch
Suspension/handling
- Yellow speed Coilovers (height and damper adjustable)
- Signature front and rear adjustable sway bars
- 15x8 +25mm Konig Wideopen wheels with near new Nitto NT01 semi-slicks (Wheels purchased from USA and weigh 6 kgs each)
- NB8B front and rear brake upgrade with Hawk HP Plus pads
- Motul RBf600 brake fluid
- Cusco Front tower brace
Interior
- Brown Davies CAMs approved Roll bar
- Sparco "Sprint V" bucket seat (with leather bolster protectors)
- Autotechnica 6 Point Racing Harness
- Momo steering wheel
- Rhino insurance approved 3 point immobiliser + alarm
- no stereo and no speakers in doors
- no passenger seat
- soft top removed (still have it)
Exterior
- OEM Hard top roof
- tow hooks front and rear
- Cosworth bonnet Vent above turbo
- Garage Vary front lip
Service
- Timing belt replaced at 160,000kms
- water pump replaced at 160,000kms
- Spark plugs replaced at 160,000kms
- Changed oil (Penrite 15w-50 full synthetic) + oil filter (3 changes so far, one after purchase and one after each track day)
Below performed within the last month (have receipts from MX5 Mania)
- New rocker cover gasket
- New CAS seal
- New rear main seal
- New top radiator hose + new turbo water lines.
Bad points
(all cosmetic)
- prior repair and paint to front left guard and bar is not the best
- bonnet has scratches and dent
- small scratches and dents mostly on rear of the car.
- rubber mould around windscreen is cracked
Extra Info
Car made 149rwkw @ 9psi on MX5 Mania's dyno and 155rwkw @ 10 psi on CRD's dyno (have dyno sheets).
The steering was heavy, it was a tight squeeze, and low enough to be a nuisance on kerbs.... I was in love! the fact that it went like a rocket was still an unknown quantity at this stage, I had only tested it up to full boost for half a second (his block is a heavy suburbia type of joint) That was enough to realise this thing was going to give me more joy than any car Id had before, and would be a potent competition vehicle in whatever event I wanted to run it in.
I got it home, got it regoed, and got the roof off!
And so it began, Only thing left was the name... after copping alot of greif for buying a hairdressers car (working in the trucking industry) I decided that "Zohan" was a perfect title for my little hairdressers car with balls of steel!
I will leave it there for now, but I look forward to sharing my experiences over the first two rounds of the NSW Khana series, Driftmob Peanut night, MDTC day, JDMST EOMM and of course updates on mods and I will even share some pics and stories from my short stint in Drifting.
Catchyas trackside,
Scotty
