BB Racing - floda and his latest MX5
floda
Postby floda » Fri Sep 09, 2011 5:06 pm
The latest MX5 to find itself parked in the garage is a July 1998 NB8A - Black with H'top. 125,500 klms and no obvious issues when collected last week. The previous owner suggested an oil change and filter and new rear brakes immediately and fronts at 130,000 klms. I have hawks for the front and rear going in next week and Anglomoil - Roadmaster 200 API SM, SL & SJ, CF with filter for the engine.
I think the centre muffler has a loose baffle and thats all I can find so far. New radiator, window wires, AC works well. H'top is clean and in good condition.
Should be fine for a first timer visit to WP in October.
Floda.
Black NB8A 1998 / Classic Red NC PRHT 2010 Sports
Hornsby / NSW
Re: BB Racing - floda and his latest MX5
Postby NitroDann » Fri Sep 09, 2011 5:22 pm
Sweet.
HP+?
floda
Postby floda » Fri Sep 09, 2011 5:36 pm
YES HP+
Only std disks at the moment, not sure how I will go at a track day. All a bit of an experiemnt but reading about the exploits of Hammer and Guran it it time for me to try it out.
The tyres are some Sumitomo items that will need replacing after one WP outing I am sure.
Floda.
Hornsby / NSW
Postby manga_blue » Fri Sep 09, 2011 6:09 pm
Sounds like almost the perfect preparation for a first track day: fresh oil, good pads, stock standard car and tyres that you don't mind destroying. :lol:
Main thing missing is a quality wheel alignment (search this site first). Would be worth checking age of gearbox and diff oil and changing brake fluids too.
floda
Postby floda » Fri Sep 09, 2011 6:20 pm
Thanks for that, brake fluid change is included next week. Stu at Spinning Wheels to be contacted for an alignment. I will have a check of diff and gearbox oils as well, thanks for that suggestion.
Floda.
Hornsby / NSW
Postby NitroDann » Fri Sep 09, 2011 6:25 pm
You should have no hastles with that brake setup as long as you fully flush the brake fluid with good stuff. Dont forget, its the fluid in the caliper that needs to be the good stuff, so you need to bleed a whole bottle through it if it hasnt done for a while.
See you there, hang on... What event and date is this? Just a clubday at wakefield?
floda
Postby floda » Fri Sep 09, 2011 6:30 pm
This is in preparation for the next WP day 23rd 10 2011 which is a club day.
Floda.
Hornsby / NSW
Postby NitroDann » Fri Sep 09, 2011 6:32 pm
Thats only 5 weeks away right. Sweet. Ill be there :P
floda
Postby floda » Fri Sep 09, 2011 6:37 pm
It is the interstate challenge NSW v VIC so be early is what I was told and first timers may not get out due to numbers. So I ma be a spectator and waiting until November.
Registered for the day already though.
Floda.
Hornsby / NSW
floda
Postby floda » Sat Sep 10, 2011 11:26 am
Onsite wash and detail for the Sports today. This is after 6 trips of 4 or less days Sydney - Melbourne or Sydney - Brisbane in the last 5 months. Before shot below;
Floda.
Hornsby / NSW
floda
Postby floda » Sat Sep 10, 2011 3:12 pm
After the wash shot, hard to see the improvement in them but well worth the $ to get it done properly.
Floda.
Hornsby / NSW
floda
Postby floda » Wed Sep 21, 2011 7:17 pm
Did the oil change and started the brake pad replacement. Got to the left rear and found a bent slider pin. A minor hickup as we chase the pin $15.00 and pressed it all apart. The rear bracket appears to be OK so we will finish the job next week now.
Floda.
Hornsby / NSW
floda
Postby floda » Sun Sep 25, 2011 12:32 pm
All done - the next step after test drive to Gosford and hopefully some WP days are;
New rotors front and rear - DBA standards for the front and MAZDA OEM for the rear, tested at 1mm over minimum size when replacing the pads and there is a slight shimmy from the front end
New tyres - most likely after 3 WP days - Dunlop Direzza Z1 Star Specs reccommended by Guran
New oil and filter
New shocks - nothing special but "in the spirit" of the vehicle so no coilovers etc
Floda.
Hornsby / NSW
floda
Postby floda » Mon Nov 07, 2011 7:45 pm
Stainless brake lines installed today. The locking front left caliper has gone away now and the car pulls up in a straight line.
kris
Postby kris » Mon Nov 07, 2011 8:03 pm
Great car Floda- i like what you've done.
Whats this business about coilovers not being in the spirit of things though ? :wink:
