ASE05 2
ASE05
ASE05 2
Postby ASE05 » Mon Sep 05, 2011 4:34 am
Well, thought I'd post some pics of our new child. 2005 Mazdaspeed Miata with 41XXX miles on the clock.
In the hands of the previous owner she's won 2 national SCCA events! He's now competing in his 2005 Corvette Z06(at least I think it is). Good bloke and loves his autocross.
Mechanically he's looked after her well but leaned on her hard (14 to 15 psi - 8000rpm redline on stock internals :shock: ).
Cosmetically it's straight with no previous accident history but it's had a crap respray and I don't think detailing was a priority for this car :(
It's also running a 5 speed box as the 6 speed shat itself. The original engine spun a bearing due to a lack of oil. We'll be collecting that in the next few weeks. The rebuild will be our winter project. All going to plan, the rebuild will be done by end of May and the new motor goes in in June. Not sure of parts to be used yet but the aim is reliable 8000rpm redline and 16 lbs of boost!
Picked her up 11/08/11 with the OEM ECU injectors and other stuff attached in order to pass the OBDII inspection. Tripped a code and the CEL came on 20 miles after getting my hands on it. Had to drive around and do all sorts of crazy stuff to get the codes showing ready. Got them ready, passed the test and the following night on the way home, she tripped the codes again!! Good thing the stock stuff goes into hiding for the next two years until the next inspection is due. Hopefully by then I have a friendly tester!
Today the return to mod status is complete. All fluids have been changed over front to rear except clutch/brake/power steering.
Lots of fun things discovered as I progressed but I'm happy now it's all together the way the boost gods intended.
Mods include;
Hydra Nemesis ECU
RC 550cc injectors with plug in clips
Cold Air intake with inlet upgrade
Flying Miata front sway bar with FM end links
FM Downpipe and hi flow cat
FM Intercooler
FM ACT heavy duty clutch and 10 lb flywheel
Shift-I RPM light
FM Performance brake kit, slotted rotors, stainless steel brake lines, Porterfield R4S pads
GFB Blowoff valve
MSM FMII conversion kit, includes turbo manifold, GT2560r Turbo and all parts were ceramic coated
AFCO coilovers front and rear
Full set of upper and lower control arms from ISC Racing with high-misalignment heim joints…link is here … http://iscracing.net/miatasuspension.html with the offset delrin bushings
Hallman Manual Boost controller
Hard Dog Hard Core single diagonal roll bar with harness bar
Removed rear sway bar
A pillar mounted AutoMeter boost gauge
17x7 Enkei PKR with Nitto 215/40/17 all round - daily - these will be sold and my 17x7 Enkei RPF1's will go on next summer
15x8 Rota RB's + 35 with Hoosier 275/35 A6's attached. - track/winter
The day we met, I fell in lurv!
Her first night at home with her proud parents
Decided I needed tidy the engine bay today - before
After
Bonnet Before
After
Cam cover before
After
Cowl area before
After
Before
After
Before
After
So, the sticker have been removed from the bonnet and I may have been a little aggressive with the clay bar. Pic's to follow once that's complete!
Sing that song, puff all night long.......
MINX
Re: ASE05 2
Postby MINX » Mon Sep 05, 2011 8:11 am
Great stuff, subscribed.
Old Dude
Re: ASE05 2
Postby Old Dude » Mon Sep 05, 2011 8:35 am
Nice .......so where abouts are you located?
Dale 8)
MX 5 2001 Grace Green
NB8B
ASE05
Re: ASE05 2
Postby ASE05 » Mon Sep 05, 2011 10:41 am
Old Dude wrote:Nice .......so where abouts are you located?
Dale 8)
Union, NJ USA used to be Redcliffe, QLD
Old Dude
Re: ASE05 2
Postby Old Dude » Mon Sep 05, 2011 1:58 pm
Dale 8)
Nice ...I spent a couple of weeks at Rutherford NJ, very handy to the big apple .Enjoy your new toy
Dale 8)
NB8B
NMX516
Re: ASE05 2
Postby NMX516 » Mon Sep 05, 2011 2:21 pm
Wow with those before and after pics as examples, you should be a car detailer!
Look forward to reading all about the new ASE mate :beer:
BadBong
Re: ASE05 2
Postby BadBong » Mon Sep 05, 2011 2:59 pm
Mate... that is by far my favourite colour for a SE... great buy!
Novice1
Re: ASE05 2
Postby Novice1 » Mon Sep 05, 2011 7:07 pm
Looking good Derek. Looking forward to updates.
Cheers Novice1
ASE05
Re: ASE05 2
Postby ASE05 » Tue Sep 06, 2011 7:27 am
Well, here's a bit of yesterdays efforts. All done whilst killing 12 beers!
Headlight Before
Headlight After
Bonnet Before(well, after sticker removal and being nasty with clay bar)
Bonner After
I've discovered the best polishing pads....12 months after getting out of detailing :roll:
ASE05
Re: ASE05 2
Postby ASE05 » Tue Sep 06, 2011 9:40 am
Oh yeah!
Escort Passport 9500IX hard wired. This thing has already paid for itself 10x over 8)
timk
Re: ASE05 2
Postby timk » Tue Sep 06, 2011 10:39 am
Looks the goods! 8)
How do you find the AFCOs?
ASE05
Re: ASE05 2
Postby ASE05 » Tue Sep 06, 2011 12:42 pm
saboteur wrote:Looks the goods! 8)
Not sure yet. The roads are savage here and I haven't even checked the settings yet. There's a LOT of straight highways and not much else in my daily commute. There are some corners around here but I'm still trying to get used to the car.
There's one on ramp I hit in TheMissus MS3 that I can successfully take at least 5 MPH quicker in this ( ~40MPH maxed in the MS3, around ~45 MPH in the MSM).
I think the AFCO's come from FM with 350lbs springs. She's running 850lbs springs all the way round. Getting the set up right will be trial and error for now and that's a "mods" down the list. Winter will be here soon and she'll get jacked up to 4X4 status to clear the snow that they can't prepare for.
I can however report that a 540i BMW stands no chance on the highway 8) . It just so happens that tonight I ran into the same local with a BMW 540i with exhaust at least. We previously met in the MS3 and it was neck and neck(from 60 to at least 120 MPH). In the MSM, I had 3 car lengths on him in 3rd, about 5 in 4th and after that we both backed off 'cause our detectors were going spastic :lol: .
You know the stuff you see on youtube with the beeping of horns for a highway run? That isn't made up!
I'm beginning to enjoy the US of A!
I should add that she's now running ~11psi. It was dyno'd at 253 at 12.5psi so I think a safe guess would be 240 rwhp in OZ dyno's.
I'll leave it there for now until the rebuild is complete.
D4NM4C
ASE05 2
Postby D4NM4C » Tue Sep 06, 2011 12:48 pm
Man I want to move to the states lol, is the detector legal?
ASE05
Re: ASE05 2
Postby ASE05 » Tue Sep 06, 2011 1:02 pm
D4NM4C wrote:Man I want to move to the states lol, is the detector legal?
Legal in all but 3? states :evil:
Re: ASE05 2
Postby bruce » Tue Sep 06, 2011 2:58 pm
Cars are a lot cheaper in the US. Firearms are also legal (don't know which states).
