Gareth's Red Na6
RedMX
Gareth's Red Na6
Postby RedMX » Sat Apr 09, 2011 7:43 pm
Thought i would start, This is my ride. My red 1990 Na6!
Bought it 2nd hand off a female owner in Knoxfeild in Melbournes S/e suburbs (not far from where i work). :twisted: Pure convenience for veiwing after work had finished. Two weeks later it was mine & following that I joined here.
& this is my money pit in the curent form that i had recived it. on the 1/4/2011 was i a fool for buying this.... i think not (april fools day)
RedMX
Re: Gareth's Red Na6
Postby RedMX » Sat Apr 09, 2011 8:21 pm
8/4/2011 I had her sent to the mechinics to go for a Pre roadworthyness check.
& the mehanic to my suprise came back with a small list of things to fix.
1. Wiper Blades.
2. Rear window to be replaced (fogged vynil).
3. Front brake shudder, Replace front rotors & pads.
4. Both sun visors missing.
5. Top up master cylinder with brake fluid
& thats all, rather pleased with the effort really..... i was expecting alot worse. After work I poped down to MX5 Factory in Ringwood & purchased a set of visors and 2 vent inserts (with orbs) to replace 2 worn ones i had that i was not happy with. $40 later :D
9/4/2011
I went down to autobarn & bought some dot 4 fluid & ordered my rotors :mrgreen: . Just have to wait for them to turn up
Hjt
Postby Hjt » Sun Apr 10, 2011 12:58 am
This often helps avoid the bright headlights when a large vehicle is up your rear end.
and the visors missing is common, i took mine off since they don't have a use for me (6'4) and don't cover the side windows properly. If you require some many aftermarket places stock them.
Welcome to the obsession
RedMX
Postby RedMX » Mon Apr 11, 2011 5:01 pm
Thanks for the welcome :wink: I managed to get a stock set of visors from MX5 Factory so all good.
As for the rear window they will not let me pass with the one in it :( as that it's way too far gone :shock:
Postby hks_kansei » Mon Apr 11, 2011 5:09 pm
buy a can of a product called Vuplex
on Pam's car it seemed to help clear the window a bit, it wasn't permanent. and wasn't perfect, but it might be enough to pass RWC if you do it before the test.
RedMX
Postby RedMX » Mon Apr 11, 2011 5:17 pm
hks_kansei wrote:buy a can of a product called Vuplex
where abouts can i get this product called Vuplex?
can only try & reduce it & see if i can get it through.
Postby hks_kansei » Mon Apr 11, 2011 5:26 pm
I got mine from a local Autopro, but Autobarn and Supercheap Auto might sell it too.
cans look like that, I think it was $12 for the medium one roughly?
RedMX
Postby RedMX » Mon Apr 11, 2011 10:03 pm
hks_kansei wrote:I got mine from a local Autopro, but Autobarn and Supercheap Auto might sell it too.
[img]http://www.vuplex.com.au/images/VuPlex-cans-big.jpg[img]
Thanks, see what i can do :D
RedMX
Postby RedMX » Wed Apr 13, 2011 5:48 pm
13/4/2011
Went to the local autobarn & got some Vuplex and picked up my Rotors & Hub/Bearing kit and i found a good parts supplyer that is cheeper than Supercheep, Auto Pro & Auto Barn in most cases for Hardware.... Place called Mega Auto Parts in Wiltona (Williamstown) basicly they suply the bare basics in parts @ a good price :mrgreen:
RedMX
Postby RedMX » Fri Apr 15, 2011 4:36 pm
12/4/2011
I had a slight thought that the Vuplex might not have the balls to bring the window up to shape. So i got some Meguires Plastix (Perspex Cutters/Polish) so i got too it & used the Meguires first & then the Vuplex second.
I would like to thank my dad for hinting towards the Meguires Plastix..... dont think i would have got the result i was after with just the Vuplex.
I was verry happy with the result as that before i could not actully see out the window & now i can :)
Oh & my brake stuff that's going in tonight. ^_^
CheyneX5
Gareth's Red Na6
Postby CheyneX5 » Fri Apr 15, 2011 4:55 pm
Are they burson wheel hub assemblies?
90' NA6 - Classic Red
RedMX
Postby RedMX » Fri Apr 15, 2011 6:19 pm
CheyneX5 wrote:Are they burson wheel hub assemblies?
I have no idea, i only have them for spares. (doubt that they will go on.) I've been told by another memeber that i will not get alot out of them.
going to take the car apart tonight to have a look.
CheyneX5
Gareth's Red Na6
Postby CheyneX5 » Fri Apr 15, 2011 6:44 pm
They look like they are.
I think I mentioned to you that I have been through 3 of them in 2 months due to poor build quality...
Genuine Mazda for that kind of thing I say.
RedMX
Postby RedMX » Sat Apr 16, 2011 10:58 pm
CheyneX5 wrote:They look like they are.
Thats a bother that they can not produce a quality product :|
16/4/2011
Brakes went in today, i couldent belive how easy it was to do it on my own "with guidance"........ Next on the list for stopers is my daily drive.... (The White Whale - Moby Dick) << My 90' ea Falcon S :oops:
Also spent some time on the paint work today & aligned lights & bonnet looks like a million bucks now. :mrgreen: (i have no photo's of that yet)
And just for good measuers this is Moby Dick.
RedMX
Postby RedMX » Tue Apr 19, 2011 10:14 pm
16/4/2011 Part B
After some adjusting of the bonnet & lights it looks somewhat ok now. :roll: I have a feeling the the bumper may need a tweek.
Other than that some elbow grease & some time brought the paint back to life.
Mmmmmmm SHINEY!
and tomorow 20/4/2011 off for the full roadworthy :NA6:
