Page 1 of 3
Clubman + Turbo
Posted: Mon Mar 08, 2010 1:08 pm
by Rob E
I've had the car for a while now and finally had a chance to take some half decent pics.....so here she is.
Specs as below......
NA8CE MX-5 Clubman
Engine:
1.8 with AVO kit
GT28 Ball bearing turbo
AVO Manifold
AVO Dump
AVO intercooler
Custom made 2.5" exhaust (Metal cat to be fitted)
Turbosmart Boost controller
Turbosmart BOV
RR Fuel pressure Regulator
Walbro fuel pump
360 cc GTX injectors (550cc waiting to be fitted)
Air intake temp sensor
Link G4 Storm ECU
Carbing Strut brace
50mm Cooling pro Radiator
Body :
Garage Vary front lip
Matt Black Hardtop. Soft top removed
Black window frame surround
Brown Davis Roll bar
Craftsquare CF Mirrors
Clear side markers
Clear side indicators
Underneath
Buddy Club JNR Spec Coilovers 8kg/6kg
All Bushes replaced (Offset Camber type up front)
Exedy HD clutch
Wilwood Brake proportioning valve
Wilwood 6 Piston Dynalite calipers up front
Original calipers rear (rebuilt)
Goodridge Braided lines
Master cylinder stopper
BIG DBA 5000 series 2 piece rotors F & R
15 x 8 6UL with McGard Black nuts
225/45/15 Kumho V70A
Torsen LSD
Its currently running 10psi, but will fit 550cc injectors + Metal cat + New Intake design and then retune so i can run 12psi.
I've also got a Beatrush Diff brace to fit, and FM Butterfly brace on order. Also need to fit US R Package rear low spoiler and a rear tow hook. Im doing a few little tidying up projects too. Im loving this car 8)
Clubman + Turbo
Posted: Mon Mar 08, 2010 1:28 pm
by RawSouth
Wow what a car!
This would be my ideal NA :D
Well done Rob!
Clubman + Turbo
Posted: Mon Mar 08, 2010 1:31 pm
by Rob E
the credit needs to go to Daz who built it, i just recognised it as being a corker and snapped it up. nevertheless, i will be making some further improvements :twisted: 8)
Clubman + Turbo
Posted: Mon Mar 08, 2010 1:36 pm
by RG.net
<3
Clubman + Turbo
Posted: Mon Mar 08, 2010 1:59 pm
by Jeo
Had a chance to hit the track yet?
Clubman + Turbo
Posted: Mon Mar 08, 2010 2:00 pm
by broady
Ahhhh this is such a sick car. Me likey, a lot. Do you know any figures on power?
Clubman + Turbo
Posted: Mon Mar 08, 2010 2:10 pm
by Rob E
Jeo wrote:Had a chance to hit the track yet?
Not yet, but MDTC this Saturday, then the wife will be using it at EC Skid pan end of the month......WP in April
broady wrote:Ahhhh this is such a sick car. Me likey, a lot. Do you know any figures on power?
Chris, feels like 140-150rwkw to me. All will be revealed when it goes in for 12psi tune
Clubman + Turbo
Posted: Mon Mar 08, 2010 2:20 pm
by 93_Clubman
Looking good Rob!
Clubman + Turbo
Posted: Mon Mar 08, 2010 2:24 pm
by DaveWA
Very Nice, well done
Clubman + Turbo
Posted: Mon Mar 08, 2010 2:25 pm
by sliq
what a great example of an NA..... if you don't mind me saying, i had a hard on looking at her.
Clubman + Turbo
Posted: Mon Mar 08, 2010 2:37 pm
by 93_Clubman
maybe time to sell the nb8b & buy an na8 sliq :P
Clubman + Turbo
Posted: Mon Mar 08, 2010 2:54 pm
by Hammer
I love the front on and rear on stance. The wheel offset and camber really sets it off.
Clubman + Turbo
Posted: Mon Mar 08, 2010 3:07 pm
by Rob E
yeah, im going to wind it down about 10mm front and rear i think, no more. The 6UL have really grown on me too, perfect combination of stance/width/weight/brake clearance for me.
Once i do power + bracing the next step is seats and harnesses........probably need a beefier clutch too :P
Clubman + Turbo
Posted: Mon Mar 08, 2010 3:33 pm
by Adam_NAclubman
I like that car, its just like mine but better in too many ways
Clubman + Turbo
Posted: Sat Mar 20, 2010 3:09 pm
by Rob E
@ MDTC
The car developed what i think is some kind of fueling problem, after 3-4 minutes hard it would start to hesitate, splutter etc...almost like a soft cut rev limiter. Will get the new injectors in next Saturday and have retuned, will check out the pump too to make sure its up to speed.
