A big Thank You
Posted: Fri Sep 04, 2009 6:14 pm
To the service Dept at Eurocars.
Thanks guys, you've convinced me that I'd be wasting my money getting you to service my car.
Doubts started when I had new tyres fitted a couple of months back.
I watched as the guys at Jax attempted to get the wheels off, then after about 30mins, came in to tell me that the locking nuts had obviously been tightened with a rattle gun and had been distorted to the stage that they could not be removed without destroying them.
Eurocars rotated the tyres at the last service.
I shelled out for a new set of locknuts and watched as Jax tightened them with a torque wrench.
Today, after a drive thru Nashos, I decided that I'd do an oil/filter change..Was a little perturbed at just how tight the sump plug was....but then, I thought, I've never owned a Mazda before, maybe they just sieze a little between changes.
Flipped open the little hatch underneath, grabbed the oil filter, and couldn't budge it. Wormed my other hand in through the wheel arch, and with two hands, still not budged.
Grabbed a torch and had a quick look.
Bugger me if there weren't claw scratches on the sides of the filter where it had been FITTED!!!! with a filter wrench.
Fortunately I had a wrench small enough to get in there and with quite a bit of force on the end of a 10" ratched, and a couple of turns before it came loose, the filter was able to be removed and a new one fitted.
Cost me $87.00 for 5litres of 0/40 Castrol Edge and a Ryco filter....
Thanks again Eurocars.....I won't be back!
