NA6 - Weekender/Project: It got backed into :-(
Posted: Sat Feb 21, 2009 11:00 pm
Hi all, i'm Adam and i'm a "noob" here, but a few of you might know my username from Ausrotary.com.
Anyway this thread is for my sisters 1990 NA6 that i'm helping here restore and do up a little.
I look forward to sharing a few stories and maybe a few new ideas back and forth.
So here goes the good bad and the ugly..
I found the car for sale on this forum by mekros (Rob) and after lookingat another 5 MX5's the same day we decied this was the one
We're currently doing a few of the roadworthy items and a few other things upfront, the short list of things to fix is as follows:
Replace Thermasat housing gasket
Remove window home fitted window tint (in progress)
Full cut and polish and interior detail
Replace radio fascia
refurb centre console
investigate clutch throw (very short through on pedal)
Change gearbox oil
Fit an antenna
Decarbon window switches and wire in relays to take the load (this is a trick we use on the RX-7's that works wonders for fast glass)
Fit central locking and alarm (in progress)
Clean and lube up door handles
After that we're looking at new carpet, a respray including the hardtop, refurbing or replacing the rims.
Fom there some mild mods, lowered coils, maybe uprated shocks, sway bars and bracing
Heres all the "BEFORE" pic's
As advertised
Faded / oxidised paint work
a quick buff cut test section
You can really see the oxidised pain when comparted to the cut section.
We expect the metal panels to buff up fine, but the plastic work is highly unlikely.
Cracked radio fascia
Faded trim
and the car's first mod
Many more updates to follow soon!
Change gearbox oil
Fit an antenna
As advertised
Faded trim
