#### LIGHTYEAR'S TURBO NA6 CLUBRACER ####
lightyear
Infinity & Beyond
Postby lightyear » Sat Jun 07, 2008 5:21 pm
I Bought an MX5 on sat 31st of may from glen via this forum. I am going to get it rego'ed next week i hope. It is booked in for tuesday for the r.w.c.
So far i have pulled all the turbo gear off and installed all the stock bits.
Took the roll bar off and the chassis brace from behind the seats.
Put the carpet and trims in. It looks a bit more standard now. Hopefully not too many dollars to pass r.w.c.
Juffa
Postby Juffa » Sat Jun 07, 2008 9:29 pm
There is a very good chance that the RWC will require the windscreen to be replaced. If so and you are looking for someone to install one;
FX Auto Glass
0412 897 844
fox Partsch is his name. Has fitted a number of MX-5 windscreens for me. Cost around $150 and he comes to you.
Not affiliated in any way....just a happy customer.
Good luck with the RWC.
J
lightyear
Infinity & Beyond
Postby lightyear » Sun Jun 08, 2008 4:01 pm
Cheers, I need all the help i can get on a small budget. I am going down to mazfix tuesday morning with the car and see if i get get all the bits i need. It's very loud now as the turbo was acting as a muffler. So will be changing the rear half of the exhaust too.
lightyear
Infinity & Beyond
Postby lightyear » Tue Jun 10, 2008 9:03 pm
Got the r.w.c list today. Not too bad, -
I need to change the steering wheel
Seats need changing- got some high back race seats going in now.
Clutch slave cylinder is leaking
And i need a new set of tyres
Plus a couple of small bits like wipers.
lightyear
Infinity & Beyond
Postby lightyear » Tue Jun 17, 2008 9:34 am
lightyear
Infinity & Beyond
Postby lightyear » Tue Jun 17, 2008 9:44 am
oops
lightyear
Infinity & Beyond
Postby lightyear » Tue Jun 17, 2008 9:45 am
I am doing something wrong here. Any help??
lightyear
Infinity & Beyond
Postby lightyear » Tue Jun 17, 2008 9:48 am
lightyear
Infinity & Beyond
Postby lightyear » Tue Jun 17, 2008 9:51 am
Dodgy pic of seats
lightyear
Infinity & Beyond
Postby lightyear » Tue Jun 17, 2008 10:00 am
I have passed the R.W.C. Now i need to go to vicroads on wed to get the inspection done and give them some more money. And i will be ready to go.
I have put the turbo gear back on and changed the intercooler as well as the intercooler piping. I have shortened the I.C inlet buy over a 1m buy going thru the wheel well. And i painted all the polished alloy pipes to satin black as well as the intercooler. I am puting an under-tray in from the bumper to the radiator today. To help with airflow thru the intercooler as well as the radiator.
I also disconnected the blow off valve as it was dumping all the air and every gear change i had to wait for the pressure to build up again.
I have installed some race seats and lifted the roll bar by about 100mm so now it just touches on the soft top and is now higher than my head.
lightyear
Infinity & Beyond
Postby lightyear » Tue Jun 17, 2008 10:14 am
I also got some \"R\" spec tyres.
Blue94t
Postby Blue94t » Tue Jun 17, 2008 12:54 pm
Nice car mate.
How did you lift the rollbar 100mm?
Also I would have left the turbo gear off till after Vicroads inspect it. They might make your life difficult if you get someone from Vicroads is smart enough to pick it as an aftermarket turbo set up.
lightyear
Infinity & Beyond
Postby lightyear » Tue Jun 17, 2008 6:05 pm
I would have left it off if i knew i had to take it for insepction. I thought i would just pay for the rego without the car.
I bolted it to the top off the seatbelt bolts instead of the bottom and extended the support legs with some steel tube. I will weld some more tube into it when i have time to make the cage more supportive.
lightyear
Infinity & Beyond
Postby lightyear » Tue Jun 17, 2008 6:11 pm
I made a turbo heatshield and an alloy undertray to help the air thru the intercooler.
lightyear
Infinity & Beyond
Postby lightyear » Tue Jun 17, 2008 6:24 pm
These pics come out a bit bigger.
