Postby 16bit » Sun Nov 30, 2008 5:30 pm
indeed. there is small gap in the undertray between where the splitter ends and the chassi rails start. it then goes all the way back to the rear subframe brace. still deciding on the type of rear diffuser I want. in theory it should work quite well. reducing lift quite a bit. It would take quite a bit to make net downforce on a 5 but reduced lift is always a good thing. the splitter and cannards will be taken off when I can drive again as they look a little funny and the splitter is just too low.
