Venturing down the slippery slope - SKYHI Motorsports SE
SKYHI
Re: Venturing down the slippery slope - TCR's SE
Postby SKYHI » Tue May 30, 2017 2:46 pm
AM, and then doing passenger laps at Lunchtime. You having a run?
Postby Magpie » Tue May 30, 2017 2:51 pm
Planning on being their PM, depends on the other half (doctor appointments)
SKYHI
Postby SKYHI » Tue May 30, 2017 3:20 pm
Well if I see you arrive in time and have the chance, I'll drop by to say hi, or feel free to do the same :)
SKYHI
Postby SKYHI » Mon Mar 26, 2018 12:48 pm
Can't believe it's been nearly 12 months since I posted in this thread. :shock:
I've had a huge year and the car has spent most of it parked under a car cover sadly. Last time I backed it out to take it for a drive, I noticed a small pool of gearbox oil on the ground, so I parked it up until I had a chance to look at it. That was probably about 6 months ago :(
I finally had some time to look at it over the weekend so I jumped in to back it around into the proper Garage, and predictably the battery was pretty flat. After jump starting it I got it up into the Garage and up on stands. Undid the under trays and gave the gearbox a good clean. Once I had I discovered the culprit....... a loose drain plug. :oops: I can't believe I've put off looking at it for so long, for it just to be something so simple.
Anyways, drained the remaining fluid out, refilled it up with some new fluid and took it for a run. No other leaks so it looks like I'm back on track. :D
Hopefully buying some new rubber for the Adavnti Storm S1 wheels in the next couple of weeks, and then just to fit my Sparco seats I've had sitting in a box for nearly 18 months now. Then I'll just need a harness and a good going over before taking it out to the track for it's first run.
Postby Okibi » Tue Mar 27, 2018 1:57 am
At least it was a cheap and easy fix and your caution avoided a more expensive problem.
SKYHI
Postby SKYHI » Fri Apr 13, 2018 3:31 pm
Decided to repopulate this thread with images :)
Photos from the original sales advert.
First outing.
Second day of ownership, small paintless dent removal :)
First "roof down" run. Loved it :)
Followed by a spot of cleaning.
Day out at Tamborine Mountain.
Followed by another.
Bought some new Continentals for the standard SE rims.
Quick check over the engine before the run down to NitroDanns.
Safely arrived for the drop off.
Bought some Sparco Sprints to go in whilst away at Danns. Still not in unfortunately :(
Finally done at Danns and ready for collection.
MX5 run with Daffy and the gang.
ManiacLachy
Engaged
Postby ManiacLachy » Fri Apr 13, 2018 3:40 pm
Such a good colour, that Velocity Red. That was a fun run with Daffy, now that it's getting a little cooler I'd like to get out for a few more drives.
SKYHI
Postby SKYHI » Fri Apr 13, 2018 3:41 pm
Yes mate, it was a good day out, and I need to do it again soon.
In other news, I finally got some tyres fitted to the 15 x 8 Advanti Storm S1 wheels, and picked up some 949 Racing wheel nuts at the same time. Bare rims weigh in at 5kgs, and with the 205/50/15 Yokohama AD08R tyres and wheel nuts they weigh in at 14.7kgs. In comparison, the 215/40/17 Continental tyres on the standard Racing Hart SE rims weigh in at 17.1kgs, so a saving of 2.4kgs per corner.
Photos on the car to follow ;)
ManiacLachy
Engaged
Postby ManiacLachy » Fri Apr 13, 2018 3:56 pm
What a coincidence, I have a very similar package for my car coming next week :wink: I plan to do the weigh in as well and see what the difference is.
Be sure to post your thoughts on the feel with the new combo.
Postby bruce » Fri Apr 13, 2018 4:23 pm
Me likee con-cavee wheels (I like dishy too).
Postby Magpie » Sat Apr 14, 2018 6:47 am
I like my Storm's as well! Try the Nankang Ar-1 225-45-15 on them next :)
Also if out Willowbank way give a shout and call in for coffee.
SKYHI
Postby SKYHI » Mon Apr 16, 2018 10:01 am
I am looking to compete in the Street Class at Time Attack, so need to stick with a treadwear 140 or higher which rules out the AR-1 unfortunately. Was torn between the AD08R or Federal RS-RR in 205/50/15or the Hankook RS4 in 225/45/15, but decided to go with these and see what they're like. Especially if I decide to give the WTAC event a crack in 2019 ;)
Didn't even think to stop in and say hi whilst out that way, thought you were at work?
SKYHI
Postby SKYHI » Mon Apr 16, 2018 10:44 am
Went out to the Jap Nats at QR on Saturday and snapped a couple of photos whilst I was there. Unfortunately the weather wasn't conducive to having the top down.
One step closer to getting back out on the track :)
Postby Magpie » Mon Apr 16, 2018 10:53 am
TCR wrote:Didn't even think to stop in and say hi whilst out that way, thought you were at work?
I was and not happy that I had to miss Jap Nats :(
ManiacLachy
Engaged
Postby ManiacLachy » Mon Apr 16, 2018 10:58 am
Thoughts on the wheel/tyre combo?
I'd like to do a few track days soon, but mine will be more along the lines of club days than Time Attack. I'm quite inexperienced when it comes to track work, I need to learn.
