Speed's boosted NA6
speed
Re: Speed's boosted NA6
Postby speed » Tue Jan 03, 2017 7:07 pm
I was expecting to receive my flanges today but instead received a text from Australia Post saying that they probably won't come today :(
In preparation, I bent up some hangers to go into the stock NA6 locations. Welded 3 to the muffler and another on the mid pipe.
Then I received a call from mitre 10 advising that my threaded tap had arrived.
Picked it up and started to drill and tap my sump.
I wanted to fit it further back but with the engine still in the car I chose the easiest location that I could get my drill into nice and square.
I do have another sump that is tapped to clear the air con compressor. I'll be sure to fit that one when I eventually build the spare engine just in case I decide to refit the air con.
Fingers crossed that my flanges arrive tomorrow so I can weld them to my new cat and finish the exhaust.
Once that's done it's only the intercooler piping to be welded and a few hose clamps fitted along with a BOV and I should be able to start her up :)
smy0003
Postby smy0003 » Tue Jan 03, 2017 7:35 pm
Excitement!
Sent from my LG-H815
[b]Then: Sunlight Silver NB8B
Now: Chaste White NA8
speed
Postby speed » Wed Jan 04, 2017 12:05 pm
Flanges arrived today!
Now tacked up.
Just need to tack up the tail pipe then I can take it to someone that can actually weld :)
speed
Postby speed » Wed Jan 04, 2017 12:57 pm
And tail pipe tacked.
Comes out at a bit of an angle toward the drivers side but was hard to hold in the perfect spot so this will have to do :)
speed
Postby speed » Wed Jan 11, 2017 7:57 pm
Mrs Speed picked up my exhaust and cooler pipes from the welder yesterday.
It all needs a good clean but here's the finished IC piping and IC bracket.
I made the bracket this way to bolt into factory bolt holes and to minimalise blocking the radiator.
The cooler piping, being aluminum is super light.
The 3 fittings are for IAT, ICV and BOV.
speed
Postby speed » Wed Jan 11, 2017 8:05 pm
This also arrived today.
Nevyn72
Postby Nevyn72 » Thu Jan 12, 2017 2:18 am
Sorry mate but none of those pictures worked..... :|
rascal
Postby rascal » Thu Jan 12, 2017 6:46 am
Nevyn72 wrote:Sorry mate but none of those pictures worked..... :|
I can see them just fine..
speed
Postby speed » Sat Jan 14, 2017 9:39 am
Cleaned up the piping with some thinners.
Received the quality stamp of approval from my little helper.
Intercooler and bracket is next then will fit to the car with the new silicon joiners and stainless steel T-clamps.
Daffy
Postby Daffy » Sat Jan 14, 2017 11:43 am
Looking forward to them under bonnet pics when the pipings in! Looks like its all sailing along well so far!
viewtopic.php?t=73496
speed
Re: RE: Re: Speed's boosted NA6
Postby speed » Sat Jan 14, 2017 12:20 pm
Daffy wrote:Looking forward to them under bonnet pics when the pipings in! Looks like its all sailing along well so far!
Thanks Daffy.
Here's the test fit pic.
Have the clearance that I was expecting.
Just wish that I had angled the barb for the idle control up a bit.
I had expected that I would need to trim it down but just not sure if an S Pipe will still work.
speed
Postby speed » Sat Jan 14, 2017 1:37 pm
I cut down the barb for the idle control and managed to get a hose on but is kinked as expected.
I'll have to sort a better option to replace it in the future.
Eventually I'll be going for a boxed pod filter but for now this is how the engine bay looks.
From the top you don't really see much of the intercooler piping.
I'll be putting a plate on the original thermostat neck and replacing it with a freeze plug when the built engine goes in.
I also plan to make a heat shield for the turbo and manifold which will hide it some more.
Daffy
Postby Daffy » Sat Jan 14, 2017 2:38 pm
Heres an idea, just thinking if you wanted to save the drama of fabricating something....
http://trackdogracing.com/heatshield.aspx
speed
Postby speed » Sat Jan 14, 2017 4:23 pm
Daffy wrote:Heres an idea, just thinking if you wanted to save the drama of fabricating something....
Thanks for the suggestion.
It looks more like a blanket.
I'm really after something that looks more OEM but it will all depend how desperate I am for time.
speed
Postby speed » Sat Jan 14, 2017 4:27 pm
Exhaust all welded up and bolted in.
Has adequate clearance and doesn't bash into anything when I attempt to sway it side to side.
Tail pipe ended up being pretty good. Slight angle but in the centre of the cutout and good enough.
