NA6 and custom ECU plans
Re: NA6 and custom ECU plans
Postby hks_kansei » Wed Aug 09, 2017 1:43 pm
StanTheMan wrote:Could he perhaps source a NA6 alternator & crank pulley? I think that's what they do on the swaps. But thats getting into some cost....
Not to mention that totally ruins the whole "plugin" aspect.
In saying that, I wouldn't be shocked if there are universal voltage regs out there, hell I know motorbikes use similar, so it would likely be easiest to just wire one of them in and send the regulated voltage to the ecu etc.
StanTheMan
Postby StanTheMan » Wed Aug 09, 2017 2:20 pm
If someone like Ronin is looking for a cheaper solution.....
MS2 PnP $1500 landed including WB 02
MS3 PnP $1700 landed including WB 02
if he is unlucky he'll have to pay 5% import duty + 10% GST on top of that so the Ms2PnP for his NB8A would be closer to $1600-1700 landed
speediuno $250 +
WB 02 $200
2nd hand altinator & crank pulley $150?
IAT $15
CAS $100?
a bit of mucking around with wiring.
add another few bits & pieces and you are looking at say $750 all done thats half the price of the MS2PnP
If he is capable of doing his own harness. you wonder why hes not getting a DIY MS2 for about $750 about the same. I havent done the sums on that....Thats an estimate.
But for an NA6.....this is great
StanTheMan
Postby StanTheMan » Wed Aug 09, 2017 2:44 pm
I just did the numbers on a MS3 DIY and its more like $1300 inc. WB + import duty & GST.
according to https://trubokitty.com
makes the ECU in this thread quite attractive.
noisymime
Postby noisymime » Wed Aug 09, 2017 3:39 pm
There are a number of standalone alternator controllers around for the NB that would all be cheaper than replacing the alternator etc.
Eg: http://westfieldmx5.sgrkempen.be/alternator-pcb/
You can also make the circuit if you want for about $10, but that might be getting a bit DIY for you
Ross
Postby Ross » Thu Aug 10, 2017 3:50 pm
So, I did something silly and pulled the trigger on one of these :shock: , getting the IAT sensor from noisymine too.
Waiting for it to arrive and looking at viable options for a VTPS and decent Widebands, any suggestions??
When I get started i'll start a garage thread and you can all laugh at my misadventures :oops: I'm sure there will be many
So much for wanting to keep the car stock!!!
Ross
1990 BRG V-Special, NB Koni sport with King springs, MS-03's
StanTheMan
Postby StanTheMan » Thu Aug 10, 2017 3:59 pm
I use the LC2 controller & Bosh 4.9 sensor. There are plenty other ones which are cheaper. I got mine from Amazon for around $200 AU. that incudes a gauge. The gauge is ugly and Ive resorted to using my phone directly in front of me. But I run a mega-squirt. & MS Dash.
Ive not pulled the trigger on the VTPS. I run on MAPdot. on heavy acceleration it goes just a fraction lean but nothing drastic. I haven't pulled the trigger just yet as I'm currently looking at rebuilding or upgrading to 1.8 VVT. Patchy's engine is tired. Also just found a massive puddle of oil under it. Not sure if its mine or the Golf that parked there this morning...... :shock: I have the sneaking suspicion that its the German engineering & engine building. I can say that cause I'm a Kraut.
Postby hks_kansei » Thu Aug 10, 2017 4:04 pm
As far as the variable tps goes, pretty sure the NA8 and NB had them from factory and it's only the NA6 with the old "on/off" type
I wouldn't put any money on my memory though.
StanTheMan
Postby StanTheMan » Thu Aug 10, 2017 4:14 pm
You are correct.
NA6 have an on/off type VPS
upgrades are BMW, Holden VL, are a few. But you need to be creative attaching it.
Ross
Postby Ross » Thu Aug 10, 2017 4:30 pm
Yes, all the info I've got says the NS6 TPS is basic on off.
The Holden VL VTPS with a mounting plate seems do-able from interweb reports.
I've seen mention of a plug and play BMW VTPS but can't get exact details of which one, conflicting information on this one.
The LC-2 kit on the innovate website doesn't have a guage, is a guage important?
Ross
StanTheMan
Postby StanTheMan » Thu Aug 10, 2017 4:40 pm
Its nice to see where your AFR's are going.
Ive mounted mine in one of the round heater jets. Its just a little off too far on the side. although better than looking at a laptop.
On the phone which is mounted pretty much in sight. It tells me target AFR & Actual AFR amongs a few other things. I can see whats going on. I cant tune on the phone though. But can log. Its kinda nice to know where to go looking. If the EGO Correction is over 5% you just go looking for that part of the map when you do tune. Or refer back to it in your log. ( at the start good chance it will be out more)
Check with the OP if you can attach your phone via a cable ( i cant recall right now). I know hes been talking about wi-fi.....not sure if has it though without going through the whole thread.
Either way works. I just find the phone easier. When the phone is attached. I never look at the gauge.
StanTheMan
Postby StanTheMan » Thu Aug 10, 2017 4:44 pm
https://www.diyautotune.com/product/innovate-standalone-gauge-kit-w-lc-2-blue-db-gauge-3795/
that works out to be about $350 posted. Maybe even more
check Amazon. You might just get an ugly colour display but I got it considerably cheaper.
https://www.amazon.com/Innovate-Motorsports-Wideband-Gauge-Bosch/dp/B001QFH2S6/ref=sr_1_2?ie=UTF8&qid=1502344102&sr=8-2&keywords=LC2+wideband
less postage too $35US on Amazon instead of $60 US
Check other systems as well. Thats just the one I chose.....
Ross
Postby Ross » Thu Aug 10, 2017 4:55 pm
Thanks STM :beer: :beer:
Ross
StanTheMan
Postby StanTheMan » Thu Aug 10, 2017 4:55 pm
Dont bother about getting the exsaust bung either. If you get the Bosh 4.9 it fits into your exsiting exsaust. Unless you want to run 2 sensors....
Id install the WB first see how it goes. Its just a matter or changing one wire when you install the ECU later
IIf & when you install the WB this particular one can run on a narrow band signal and you can connect it to your standard plug just near the CAS
some others can too.
noisymime
Postby noisymime » Thu Aug 10, 2017 5:00 pm
In terms of more low priced wideband controller options, I've used each of the below with good success:
Ross
Postby Ross » Thu Aug 10, 2017 5:09 pm
Thanks guys,
so much info, so much reading to do, and we haven't even got to tuning yet :shock:
I'm so in over my head with this, but it's going to be fun :D
Ross
