speed freak wrote:Anyone know where the 2.5l came from? Was there a limited number built or the 2.5 from another car?
Rhys, John bought the 2.5 to put it into his NC. There are no limited build variants. It is all aftermarket modifications.
Regie wrote:speed freak wrote:Lokiel wrote:+1 on John Toomer's NC, it's the only NC I've ever liked the look of.
I dunno Regies's NC looks good.
Looks great though, seen it at Lakeside a couple of times.
you can get the 2.5 from the Mazda 6, 3SP25, put the 2l head on it and it fits in
oh thanks for the complement
Regie wrote:yep they are gutless after 6000rpm
some nice cams will fix that though
Kev05 wrote:speed freak wrote:Anyone know where the 2.5l came from? Was there a limited number built or the 2.5 from another car?
Regie wrote:wow, that NC has changed a fair bit since I last saw it
no any NC carbon parts being made??
speed freak wrote:Looking good![]()
How good are the braided brake lines hey? I couldnt believe the difference it made when I got mine put on.
With the innovate oil temp/press gauge does it come with the 'normal' screw in type sesnors that would go into say a oil filter relocation kit port?
Also where abouts have you routed your wires for the gauges? I cant work out how to get them through the firewall and into the engine bay. Meaning I cant find a rubber grommet that leads to behind the dash somewhere.
kenson wrote:I agree with the air con vent. I'm not going to give up my aircon!
I'll do the same as you in the longer term.
Thanks for the info about the shift light. Looked it up, good reviews!
As for ECU, I have the older Adaptronic (e420C) and still need to run the stock ECU for the electrical stuff. So far so good (aircon, radiator fans).
Though I'll give you more feedback once I get the car dyno tuned.
[edit] That is the manifold/turbo combo I also want to head down too. Did you check out the FM manifold? Or going for local? That's a good price for the SMB.
tomli123001 wrote:speed freak wrote:Looking good![]()
I will take some good photos for you this week.
