Andrew's '93 NA6 - KL V6 swap
Beelzeboss
Re: Andrew's '93 NA6 - KL V6 swap
Postby Beelzeboss » Tue Dec 20, 2011 8:48 pm
Awesome.
Got the passenger side engine mount bracket done today.
And made a start on the drivers side bracket
Then I took a few pics of the man cave where I've been making all the parts for the swap.
Andrew
NA-6 2.5 KL V6
http://barberprecision.com.au/
Jace
Postby Jace » Tue Dec 20, 2011 10:22 pm
I'm jealous! ^
Postby NitroDann » Tue Dec 20, 2011 10:28 pm
Looks like a Tig??? But isnt...?
Postby Lokiel » Tue Dec 20, 2011 10:33 pm
Stop showing pictures like that, you're making me feel inadequate and wanting to go out and buy a lathe!
Hjt
Postby Hjt » Tue Dec 20, 2011 11:20 pm
His workshop is awesome, I was jealous just walking over the giant amount of random engine parts
zossy1
Postby zossy1 » Wed Dec 21, 2011 2:39 am
That oil filter issue has come up with all the other "Kliata" swaps I have seen on the interwebz. Seems like an easy fix with a remote filter mounting kit...?
Looks good so far. What intake are you going to use? Custom? I seem to recall one of the others using modified GSXR1100 TB's on a custom mani...?
Beelzeboss
Postby Beelzeboss » Wed Dec 21, 2011 12:17 pm
Thanks guys, I've been doing machining as a hobby for many years hence all the machines. I'm also looking for something I can make and sell to make a bit of money. Any suggestions?
It is a tig, lol
I'd love to go ITB's but I can't see how they'd fit under the stock bonnet. At the moment I'm planning on making a custom manifold using the stock intake flanges cut down to about 30mm high and welding on my own intake runners and plenum. The throttle body is a very weird shape because the original manifold had that Mazda VICS system so I might use a throttle from another car.
The oil filter fix isn't too difficult as you point out, I think I'll make my own relocation setup
It looks like I won't have to go dry sump because there's room for a decent size normal sump.
Andrew
NA-6 2.5 KL V6
Apu
Postby Apu » Wed Dec 21, 2011 1:35 pm
Jeez! A whole range of things! Gear knobs, shifter surrounds, all sorts of replacement brackets...
I'd be going crazy...if I knew what to do!
16bit
Vehicle: NB8A - Supercharged
Postby 16bit » Wed Dec 21, 2011 2:13 pm
mustang 4.6 v8 throttle bodies are cheap as chups and about 70mm i think.
zossy1
Postby zossy1 » Thu Dec 22, 2011 3:16 am
Beelzeboss wrote:I'd love to go ITB's but I can't see how they'd fit under the stock bonnet. At the moment I'm planning on making a custom manifold using the stock intake flanges cut down to about 30mm high and welding on my own intake runners and plenum. The throttle body is a very weird shape because the original manifold had that Mazda VICS system so I might use a throttle from another car.
I think I could live with a small bonnet mod for ITBs ;)
Keep up the good work!
taminga16
Postby taminga16 » Thu Dec 22, 2011 9:39 am
Some of these, there are a number of people tracking NC's ATM and I feel sure that you would raise some interest.
Greg.
Beelzeboss
Postby Beelzeboss » Thu Jan 05, 2012 6:12 pm
Thanks everyone, lots of good ideas. There are a few I think I'd be able to make. 16bit I'll look into those throttle bodies, cheers.
I could too, but I don't think the engineer will allow it. I'll make sure to ask next time I see him.
I was away for Christmas but now I'm back and I'm aiming to have the car on the road by the end of the month. There are a lot of parts in progress at the moment including the sump, intake manifold and oil filter relocation plates.
Engine mount bolted to block
Intake manifold in progress. The flanges have been milled to height and I've made 6 aluminium stubs to weld on.
Oil filter relocation plates and hose barbs. I'm welding them on because I don't have a big enough tap for a 5/8" barbed fitting.
Air conditioning delete
This fitting seized when it was nearly undone, then I managed to partially round off the aluminium nut :evil:
Sump nearly done, it's a bit further along than this because I took the photos this morning.
36-1 wheel I made to fit the stock pulley. I have to make another because it slipped on the dividing head as I was machining it :evil: I turned off the stock 6 tooth wheel then TIG welded on a ring and cut 36 teeth in it. I should have cut the teeth when it was mounted to the pulley rather than just holding the ring in the chuck.
I hope there will be many updates in the next few days.
Andrew
NA-6 2.5 KL V6
Beelzeboss
Postby Beelzeboss » Sun Jan 08, 2012 8:53 pm
Today I almost finished the sump. Hopefully tomorrow I'll get the oil pickup finished so I can install them both on the engine. I might also be able to finish the oil filter relocation plates.
Andrew
NA-6 2.5 KL V6
Hjt
Postby Hjt » Sun Jan 08, 2012 11:51 pm
Nice welds mate, did you have many hiccups?
JG
Postby JG » Mon Jan 09, 2012 8:06 am
looking good mate... subscribed to watch the progress!
2000 Red NB8B - 紅玉
