NitroDann's Long Awaited Garage Thread
Re: NitroDann's Long Awaited Garage Thread
Postby NitroDann » Sun Jul 17, 2011 9:43 am
thanks for the advice.
Ive been able to over heat these na6 brakes on the street, and this cooling setup cost 30 dollars and believe it or not all up weighs the same as the stock steel backing plate alone.
Its finished now, it looks awesome and well, it makes a good desktop background :D
Ok...justification of effort aside The pads im most interested in are hawk blue and the xp12s. Ive got a quote for both from miataroadster and the price for both isnt too bad.
I assume youve tested many pads, why the Hawk (blues???) in particular? Id be happy to run the same pads as you as our cars probably weigh the same and your N/A setup is probably similar horsepower to mine, give or take a bit.
Boyracer
MX-5 Encyclopedia
Postby Boyracer » Sun Jul 17, 2011 10:20 am
Would be a good idea to at least upgrade the front brakes to NA8...
Over the years I have tried many different brake pad brands and compounds, the EBC were the worst and the Hawk Blues have been by far the best, have all been light cars.
Some of the racers with the big power MX5s have been using the HT-10 Hawk pads.
Postby NitroDann » Sun Jul 17, 2011 12:05 pm
Ok blues it is I spose. Whats your source/price if you dont mind :D
We all know I have a habit of opening my mouth and blurting things out, and I said I wanted to see what could be done on stock hardware, so I suppose we will find out. I know the autocross blokes in the states run the 1.6 brakes with no worries, so I figure its mostly a case of heat management with them.
We will find out...
Boyracer
MX-5 Encyclopedia
Postby Boyracer » Sun Jul 17, 2011 2:34 pm
Usually get the from Goodwin racing...about $100US...I think if you contact him he does postage for $15.
Postby NitroDann » Sun Jul 17, 2011 3:06 pm
Finished. I think it looks ghetto tough :D
I think the airdam flaps are uneven in the photos but they are made to be able to be bent so that I can adjust how much air the brake get and how much the radiator gets.
PaulF
Postby PaulF » Sun Jul 17, 2011 5:48 pm
Haha, the classic "smiley face" of the NA now has braces. :P
Postby NitroDann » Mon Jul 18, 2011 7:25 pm
As promised, tomorrow the engine gearbox and diff come out to redo the seals. Getting an extra flange on the exhaust tomorrow as the current exhaust is only 2 piece, from the headflange to the muffler tip...
Im doing both main seals, the front gearbox seal the cam seals and the diff seals. Got them through work at trade so I figured while I have the engine box and diff on the garage floor and the timing belt off it, go nuts.
Spikes also needs his front main done and im happy to do it and teach him how if he calls me back and brings over the beers :D
Hint...Hint....
Photos as usual.
PaulF
Postby PaulF » Mon Jul 18, 2011 11:17 pm
Want a hand at all? Not sure what I'm doing tomorrow, but I might be able to come over and hand you tools/spectate/commentate. :P
Postby NitroDann » Mon Jul 18, 2011 11:25 pm
sh*t yeah. I can always do with a good tool bitch!
Ill be back from the exhaust shop at 10ish.
See you tomorrow!
Spikes will be here sometime too.
Postby NitroDann » Wed Jul 20, 2011 5:40 pm
Last night 'spikes' and 'liam####'(cant remember the numbers in his username) along with 'PaulF' were around. We replaced the cam seals and front main on spikes car. While we were at it I made him a half decent working but homemade looking exhaust heatshield to help his exposed pod setup. Along with removing his cars factory intake resonance chamber, which from now on will be reffered to as a 'De-Hektifier', because it makes the intake roar far less hektik. :D
TOday with the help of PaulF Ive removed my cars engine and 6 speed, along with draining all fluids and removing a diff seal that was pretty leaky.
Plan is....
Cam seals
Front main
Rear main
CAS 'O' ring
Cam cover gasket
Diff seal
Flush and new gearbox fluid. Its only 15k old but cops an absolute flogging.
New diff fluid
Coolant reroute
And check my lifter clearances, and clearance if needed.
Ive also bought some penrite sin DOT 5.1 that claims a minimum boiling point of 305c guaranteed. Anyone had track experience with this?
Postby NitroDann » Wed Jul 20, 2011 7:19 pm
Heres the pics from today.
PaulF
Postby PaulF » Wed Jul 20, 2011 8:54 pm
Also featured: the newly created and aptly named "Basher". :mrgreen:
NitroDann wrote:Image
Postby NitroDann » Sat Jul 23, 2011 8:51 pm
So......
Update time.
A mate is coming over tomorrow (paul your invited if your keen) to give me a hand doing my seals and ripping out the dash.
The dash is coming out along with the console to pull out those last few bits of unneeded weight.
I also just fitted my fixed back fibreglass sparco. God it needs a retrim, but who cares it weighs like 4 kilos :D
Id been putting off fabing up the rails for ages, but they are done now.
Its mounted to the stock holes in the floor. and you ALMOST sit on the floor.
You can no longer see the bonnet, and im 6'1.
Woopee, Photos to follow.
Hjt
Postby Hjt » Sat Jul 23, 2011 9:37 pm
nice mate, I see you still have the charcoal canister and some useless wires in your engine bay, any plans to remove and tidy it up while your engine is out?
Postby NitroDann » Sat Jul 23, 2011 9:43 pm
Would you believe that will always stay?
If your a cop looking in my engine bay as it stands, it just doesnt look that modified, but if I do a tuck it sure will.
There arent too many reasons to book me just at a glance in there, but removing that gear will. Its 'untidy' enough to look stock, if you know what I mean.
Doesnt mean I like it. But ive never been pulled up for anything on the car since I bought it, despite the mod list. Not a single defect. A week after id bought it i got pulled up for exposed pod and ride height. It was almost stock then. Never since, and ive had MANY roadside 'random' underbonnet inspections.
