http://mx5cartalk.com/forum/viewtopic.php?f=19&t=77977
Custardtart wrote:Looked a lot of fun. Car seems to handle nicely, how do you find the balance?
Nice save at 2.30![]()
MrTurkey wrote:ECU tuning, locally I was quoted about 2k for ECUtek based tune. Seems too much. ECU swap is the other option due to my location unless someone has another idea for me? (I have a Tactrix Openport 2.0 if someone has an idea where to start fiddling)
MrTurkey wrote:I need to remove the A/C system fully now (it doesn't blow cold any more anyhow). Any idea on the belt I need?
MrTurkey wrote:Also have to dry ice the gunk on the floor.
MrTurkey wrote:Fit bushes to increase front camber to about 2.5 degrees. (Whiteline Front Control Arm Upper Bushing Camber For MAZDA MX5 NC)
MrTurkey wrote:Roll cage - next year
MrTurkey wrote:
Some of the outtakes from June, cut together into a short video.
Thanks for the ideas, if 2k is the number I'll have to budget and save for that for the ECU tune.
MrTurkey wrote:
Magpie wrote:You own scales now? These are a great asset to have if you play around with setup alot!
Without driver...
Now the decision is what tyre size, rim width, offset etc...
Without wheels the car is 905kg, I still have to remove 100kg more to get to my target AND fit rules. However for scurteneering I will fit the heaviest set of rims I have
So do I run the AD08R's (205/50/15) on:
- 15 x 7 +38 (6UL's) which would be the lightest rim
- 15 x 8 +25 (Advanti storms)
- 15 x 6.5 +38 (AV1D)
- 15 x 8 +20 (AV1D) heaviest setup
MrTurkey wrote:For the wheel combo I would vote 1 or 2, are you set on the width of the tyre?
