Nick's Daily NA6 MX5 STANCED & LOW
gslender
Re: Nick's Daily NA6 MX5 STANCED & LOW
Postby gslender » Thu Jan 03, 2013 7:32 pm
It is a tow hook, not a jacking point!? I'd be thinking and checking where it puts that lifting load on the car... That force may not be torsionally suitable for the lifting stress placed.
username
Postby username » Fri Jan 04, 2013 7:21 am
Hahahahaha. Well, at least you know for next time
"signatures - a good place for a list of your cars modifications" -Jace
niiko101
Postby niiko101 » Sun Jan 20, 2013 3:29 am
lol i guess you guys are right about the tow hook, lesson learnt for next time
did some work, frame rail kit, put my old wheels back on, put on rear lip and a few other things
[url]Image[/url]
[url]Image[/url]
will get more photos when im bothered to use a camera
niiko101
Postby niiko101 » Wed Feb 20, 2013 8:51 pm
[url]Image[/url]
[url]Image[/url]
[url]Image[/url]
[url]Image[/url]
niiko101
Re: Nick's Daily NA6 MX5 NOW TURBOED
Postby niiko101 » Tue May 28, 2013 9:23 pm
Hey everyone, i know i have not posted on this in a while and there has been a very good reason as to why not.
NB6 motor
Pauter Forged rods
Oversized Wiseco Pistons 79mm 1mm oversized
Acl race bearings
Arp rod bolts
Arp main cap bolts
Arp head studs
Toda cams 256* 9mm lift
Solid lifters
Speedflow fitting welded to sump for turbo drain
Maruha sump baffle,
Maruha 2mm headgasket
M-tuned water coolant reroute system
Turbo setup:
Custom steam pipe manifold(ceramic coated)
Garret 2871r 0.86 Tial v band housing (ceramic coated)
Custom turbo lines using Speedflow fittings
Tial 38mm External Wastegate
3" dump pipe (heat wrapped)
Waste gate dump tube (heat wrapped)
Hurricane muffler
Custom intercooler piping
Grex oil cooler setup
Front mount intercooler
Custom catch can
HKS SSQV 4
Gearbox setup:
NB 6speed
OS Giken super single
Toda light weight flywheel
Miata roadster short shift kit
Diff setup:
1.8L
Tomei TRAX 2way 4.3
Solid diff mounts
Fuel Setup:
id 1000s
Aem Fuel pressure regulator
DW300 fuel pump
M-Tuned fuel rail
-6 fuel lines from tank to rail
Ignition:
Ls2 coil setup with custom bracket and custom leads
Hks plugs
Ecu and wiring:
Haltech Spring 500
Custom wiring harness
Innovate wideband
Full Album of photos at:
http://www.facebook.com/media/set/?set=a.165242593651092.1073741841.117032171805468&type=1
or
http://s1090.photobucket.com/user/niiko101/library/Motor%20Conversion?sort=9&page=1
[url][URL=http://s1090.photobucket.com/user/niiko101/media/Motor%20Conversion/IMG_4005_zps692cfbd1.jpg.html]Image[/url][/url]
[url][URL=http://s1090.photobucket.com/user/niiko101/media/Motor%20Conversion/IMG_4016_zps39362028.jpg.html]Image[/url][/url]
[url][URL=http://s1090.photobucket.com/user/niiko101/media/Motor%20Conversion/IMG_4008_zps0d0f5ac1.jpg.html]Image[/url][/url]
[url][URL=http://s1090.photobucket.com/user/niiko101/media/Motor%20Conversion/IMG_4152_zpsb41cb3d3.jpg.html]Image[/url][/url]
[url][URL=http://s1090.photobucket.com/user/niiko101/media/Motor%20Conversion/IMG_4153_zpsad98eb33.jpg.html]Image[/url][/url]
[url][URL=http://s1090.photobucket.com/user/niiko101/media/Motor%20Conversion/IMG_4294_zps5981e5fc.jpg.html]Image[/url][/url]
Hjt
Postby Hjt » Tue May 28, 2013 9:57 pm
that engine is familiar ;)
Postby Jeo » Wed May 29, 2013 12:02 am
I see what's happened here. Nicely done dude.
PaulF
Postby PaulF » Wed May 29, 2013 7:50 pm
Someone had to...
Postby NitroDann » Wed May 29, 2013 8:50 pm
I see what you did there..
niiko101
Postby niiko101 » Wed May 29, 2013 9:43 pm
Hjt wrote:that engine is familiar ;)
Jeo wrote:I see what's happened here. Nicely done dude.
haha :)
PaulF wrote:Someone had to...
Same thing was said on club roadster and ill say the same thing here
You Sir have won the internet for the day. :)
NitroDann wrote:I see what you did there..
Postby fastfreddygassit » Wed May 29, 2013 11:16 pm
wow man!
Your build has been exceptional.
Looking forward to some pics with the new wheels.
The car is sensational in any case.
Well done sir! :NETPOINTZ:
niiko101
Postby niiko101 » Thu May 30, 2013 6:15 pm
fastfreddygassit wrote:wow man!
Thanks for the kind words, on another note
Fuel lines all done
Powder coated bits and pieces
And Stack Dash installed
All this work plus more was carried out by Suli (Pure MX5) http://www.facebook.com/PureMx5?fref=ts
He did the fuel lines, ECU, Stack dash plus much more, highly recommended
niiko101
Postby niiko101 » Mon Jun 17, 2013 3:12 pm
949 racing 6uls 15x10 +25, 225/45 r15 Hankook RS-3
Postby Jeo » Mon Jun 17, 2013 7:02 pm
Why only 225?
niiko101
Postby niiko101 » Tue Jun 18, 2013 12:46 am
widest tread i could fit under the fronts with no mods, plus got them at a steal of a price.
