mrpham's summer build
mrpham
Re: mrpham's summer build
Postby mrpham » Thu Feb 23, 2012 12:09 am
NitroDann wrote:VL TPS is like 40 bucks. Auto TB is smaller too my last measure.
Automatic TB is the same, I've measured already.
Picked up the Automatic TB and TPS for a bit less then the VL one, my hope that it'll be easy to sell when I don't need it anymore. Is $40 for a brand new VL TPS? I'm curious because that would be a bargain for people who can't find the automatic 1.6 TB/TPS. And looks to be very easy to install onto our 1.6 TB.
If people can pick up a 2nd hand VL TPS for $5-$10 from the wreckers, that would have to be the best option. Can't do any better than that.
Current Forum Specials!
mrpham
Postby mrpham » Wed Mar 07, 2012 11:33 am
Carbon Fibre Side Mirror Install - http://omgpham.com/carbon-fibre-side-mirror-install
Have just gone through TWO house moves in the past week, so I haven't had much time to post up something new. But here are some photos and a walk through of the Carbon Fibre Side Mirror install.
First step is to insert the arm into the carbon fibre housing, once that's in just tighten it gently at the top using the supplied hardware.
At the base of the arm is a large grub screw, tighten this up to make the ball joint firmer. This can loosen over time, so just re-tighten when necessary. Then attach the base to the mounting plate using the supplied hardware.
To remove the factory mirrors, simply pop off the plastic cover to reveal the screws. Once the mirror is off, give the surface a decent clean before proceeding to the next step.
Make sure to use the rubber gaskets when installing the mounting plate to your door, then simply install the plate using the supplied hardware.
The finished product!
Postby bruce » Wed Mar 07, 2012 1:03 pm
Those mirrors look good!
How much did they cost?
What is vision like?
Steampunk
Postby Steampunk » Wed Mar 07, 2012 10:19 pm
might I suggest replacing the hex-drive bolts with torx or similar security-drive heads.
Lots of stories of them walking away all by themselves.
mrpham
Postby mrpham » Thu Mar 08, 2012 12:06 am
1red5 wrote:might I suggest replacing the hex-drive bolts with torx or similar security-drive heads.
Definitely! I was looking into that, just gotta run down to the nut&bolt shop to see what's available.
Steampunk
Postby Steampunk » Thu Mar 08, 2012 12:56 am
cool beans
I have a torx kit, gimme a holler if you need them.
mrpham
Postby mrpham » Thu Mar 08, 2012 6:08 pm
1red5 wrote:cool beans
Going to have to take you up on that offer when I get back from Sydney!
gslender
Postby gslender » Fri Mar 09, 2012 4:02 am
Let me know if you need help tuning the ms2.... I'm working on a new firmware that will just rock in terms of oem-like idle and stability!
G
mrpham
Postby mrpham » Fri Mar 09, 2012 10:25 am
gslender wrote:Let me know if you need help tuning the ms2.... I'm working on a new firmware that will just rock in terms of oem-like idle and stability!
G
Hell yeah! I'll message you when I get back and can eventually start putting the MS2 in!
mrpham
Postby mrpham » Sun Apr 01, 2012 11:47 pm
Meh.... so no real updates lately. Have been busy with holidays and business so all my money and time and gone into them. First world problems?
Only thing I've done is add a new sticker, visit Zen Garage and goto to the last JDMST/Downshift meet.
Zen Garage Visit - http://omgpham.com/zen-garage-visit
Downshift March 2012 Meet - http://omgpham.com/downshift-meet-march-2012
More photos by other people - http://omgpham.com/downshift-meet-march-2012-others
mrpham
Postby mrpham » Wed Apr 11, 2012 12:01 pm
GarageStar x T3 ITB Adapters - http://omgpham.com/garagestar-x-t3-itb-adapters
I've been a slacker... I've had my ITB parts for months now and yet to install them. Well today I've started pulling the AE101 ITBs apart to clean and possibly paint. I also took the adapter plate to Chilton Engineering, can never recommend them enough, and had them check it over to make sure everything was flat. Unfortunately, the side that bolts to the head wasn't very flat at all. This was concerning because there are water outlet/inlets on that side of the head and I didn't want to risk water leaking into the intake.
Photos below of the amazing looking adapter and the re-surface that Chilton did for me.
mrpham
Postby mrpham » Fri Apr 13, 2012 7:22 pm
Not everyone is going to agree with this...
Update - http://omgpham.com/short-shifter-x-dildo
OK so I bought myself a short shifter (short throw) a couple of months back with the intention of using a very tall shift knob. The idea is to reduce the throw enough so that using a tall shift knob will cancel each other out and the throw is close to standard. However, the shifter will be a lot closer to the steering wheel for faster gear changes. WIN-WIN!
If using the tall knob with factory shifter, the throw was stupidly long (just too ridiculous). And using the short shifter kit (short throw) with a standard shift knob made it very difficult to select gears because of how short the throw was.
The shift knob I'm using was a prototype I machined awhile back:
http://omgpham.com/prototype-gear-knobs
Obviously the first step was to remove the center console and old shifter.
Also a little surprise... the new lower shifter boot I replaced not long ago is already ripped!
Removed the factory plastic bush (keep this for later) and installed the supplied aluminium spacer, slot side down. Should sit just below the top, enough room for the plastic bushing.
Then installed the supplied plastic bushing, the piece on top the supplied top spacer with the locator towards the front. Make sure the holes line up with the original.
Secure everything with supplied bolts and top plate, top part of the shifter is then installed.
And completed!
sailaholic
Postby sailaholic » Fri Apr 13, 2012 8:47 pm
Intersting to see how you like it, my car has a short throw and short grip and while it is stiffer than normal, I don't find it too stiff.
How's your other development project going? Willing to tell us what it is yet?
OurCognitiveSurplus
Postby OurCognitiveSurplus » Fri Apr 13, 2012 10:22 pm
Like the idea, not sure if I like the white.
NB8A - Twilight Blue
mrpham
Postby mrpham » Mon Apr 16, 2012 7:30 pm
sailaholic wrote:Intersting to see how you like it, my car has a short throw and short grip and while it is stiffer than normal, I don't find it too stiff.
Feels great! I really like it :)
My other project is going well, some photos below:
Behind The Scenes - http://omgpham.com/behind-the-scenes
Me and a few mates have been working hard on developing a new product for our Roadsters, it's been underway for over a month now but we're getting close to finishing our first batch. Testing was a tedious process but we wanted to make sure the fitment was dead on.
So here are some behind the scene photos =)
The raw materials.
The CNC lathe working hard.
The completed components ready to be tig welded.
