Wazman's NB8a
wazman
Wazman's NB8a
Postby wazman » Tue Aug 04, 2009 11:21 pm
The 3x2 rhs (blue beam bit) i had lying around....
The plastic's are 2.5mm thick x2 (one each side) the end plates i'm putting vertically at the end of the beam which i will bolt through to the seat belt towers are 3mm thick (CAM's spec) x2 , one each end = 11mm all up. measure distance between raised bolt points between seat belt towers and deduct 11mm :idea: cut RHS to length.
The hoop is about 13mm off the roof rib...... I've never done this before and i didn't want it to rub or touch and start squeaking while driving with the roof up,
so i left that much room for movement.
The hoops are basically 380x380..... but i asked for 2 deg of angle on each leg so it dosn't look so boxy..... they gave me extra length because i told them i was yet to confirm actual height..... Nice guys at Merridian 8)
This shot shows the clearance needed where the roof hinges and the hoop take up point will be and the 6mm plate it will sit on.
Its tight but with some patients and grinding....it shall clear nicely......
ilovedrift.com
Wazman's NB8a
Postby Okibi » Tue Aug 04, 2009 11:46 pm
I'm really enjoying your build thread, thanks for sharing everything with us. :mrgreen:
wazman
Wazman's NB8a
Postby wazman » Fri Aug 07, 2009 1:24 am
A little more work done on the roll bar today........ Me and my house mate have built cage's before but never on a car that the roof folds down......there's lots to take into account.......not just a matter of throwing in a few bars and poking at it with a bit of tig wire :|
This is my house mate's cage we did in his silvia......
The hoop base plates are welded to the main base bar end plates..... everything else is just tacked atm until we are sure it all fits and works with the roof.
Very handy house mate to have 8) qualified welder by trade......I can weld.....but nothing like this guy!
The hoop brace's take a bit of work to make sure there is no ugly gaps. scribing the end onto the hoop is done first as the other end is just a simple angle cut.
I intend on making a gusset that runs along the rear leg base plate to spread the load over a greater area.
see how much thicker the hoop base plates are than the end plates on the hoop base bar.
This is how i am going to tie the rear legs to the hoops..... Nice, simple and strong :idea:
Should be finished by the end of this weekend.... :roll:
ilovedrift.com
RG.net
Wazman's NB8a
Postby RG.net » Fri Aug 07, 2009 11:46 am
very cool 8)
Wazman's NB8a
Postby bruce » Fri Aug 07, 2009 2:40 pm
Have the local constabulary given you any extra attention?
turboalfa
Wazman's NB8a
Postby turboalfa » Fri Aug 07, 2009 8:09 pm
Car looks great,
How much work was involved in moving the air filter to the drivers side of the engine bay?
I assume it's just a matter of extending the AFM wires and possibly some sort of mount. I think it makes the engine bay look much better.
Thanks
wazman
Wazman's NB8a
Postby wazman » Fri Aug 07, 2009 9:31 pm
The pod filter install is easy as ! You just need the right size pod filter and be careful with the amount of space you have for the silicon bend, as they vary in radius at the bend, i had to cut back the one i bought to fit it, the airflow meter (afm)and the pod in the amount of space there is.
Measure all the diameter sizes you need .....the throttle body, the afm...... the pod you buy should go straight onto the afm...... i used a pod with a 75mm hole and the standard rubber spacer ring out of the stock air box to reduce the hole size to 70mm.......which is the diam of the afm!
I made no bracket.....The silicon bend holds itself up because it is so short there is no sag......
Pref take the afm with you when you go to get the pod and silicon bend..... so you get the right one's......and if need be you can convert the mm to inch's with the converter in your phone while your at the shop.....
You need to run a oil catch can off the breather line from the cam cover (not shown in my pic) (will be making one soon).....
'edit'...... and i just un-picked the afm wires from the plastic conduit far enough to reach its new location, then just taped it all back up! no need to cut or add wire.
ilovedrift.com
wazman
Wazman's NB8a
Postby wazman » Fri Aug 07, 2009 9:39 pm
bruce wrote:Have the local constabulary given you any extra attention?
Not as yet....(touch wood) its only from the side that the mx5 really looks low...... but then the whole car is deceivingly small. I've dríven past/beside 5 po po cars so far and it dosn't seem to offend them. Prob because i have a stock exhaust still, so my car is dead quiet :P until i open up the throttle and the induction noise kicks in 8)
ilovedrift.com
Mokesta
Wazman's NB8a
Postby Mokesta » Fri Aug 07, 2009 10:42 pm
That roll bar looks strangely familiar, almost like it was inspired by one I've seen before. Still, I reckon that box section is a plus...
M
wazman
Wazman's NB8a
Postby wazman » Sun Aug 09, 2009 11:49 am
Pic of me at winton.....
ilovedrift.com
turboalfa
Wazman's NB8a
Postby turboalfa » Sun Aug 09, 2009 12:03 pm
Pics look great.
Are the tyres still scrubbing?
What's next?
wazman
Wazman's NB8a
Postby wazman » Sun Aug 09, 2009 12:09 pm
One of the pro photographers took these on the day, i just found his site......Things got a little loose in the front esse's....
On the harder breaking ....like in the first photo's where the front rim is nearly up in the guard! yes.....a little....and you can see smoke coming from the tyre where its touching the guard where the back end stepped out ! fun times :mrgreen:
on the street it dosn't rub hardly at all :D
ilovedrift.com
wazman
Wazman's NB8a
Postby wazman » Sun Aug 09, 2009 8:53 pm
turboalfa wrote:Pics look great.
What's next?
Tax is in 8) Turbo time ! I'm not gunna stand for those evo's passing me on the straight's ! :twisted:
researching what injectors to get atm.....anyone care to point me in the right direction?
Stock donk+ Garret T28+ link plug@play + 040 + exhaust/intercooler +injectors (size???) (480's ??)
ilovedrift.com
Wazman's NB8a
Postby Jeo » Mon Aug 10, 2009 3:00 pm
Nothing new from me but wow your car is hot
RobH
Wazman's NB8a
Postby RobH » Tue Aug 11, 2009 10:59 am
Hi Wazman,
Below is a link to a thread that discusses suitable injectors for MX5's:
http://mx5cartalk.com/forum/viewtopic.php?f=29&t=37459&p=486772&hilit=SP+Injectors#p486772
Rob
Silver SP - KAAZ LSD, Enkei Rims, PSS9's and Project Mu Caliper upgrade kit.
