Adam's Clubman
SuperMazdaKart
Adam's Clubman
Postby SuperMazdaKart » Thu Oct 22, 2009 10:00 pm
ah well, can goto someone else then
Adam_NAclubman
Adam's Clubman
Postby Adam_NAclubman » Thu Oct 22, 2009 10:44 pm
How much, out of interest?
SuperMazdaKart
Adam's Clubman
Postby SuperMazdaKart » Fri Oct 23, 2009 6:28 pm
Bout $250 should be good for all four.
Adam_NAclubman
Adam's Clubman
Postby Adam_NAclubman » Sun Oct 25, 2009 7:09 pm
It started! :D Swapped the fuel lines around and it started right away... I'd forgotten that the fuel pressure regulator has a one way valve so hooking it up backwards will bring things to a screaming halt
Sounds a bit tappety though, and quite a bit of smoke started coming off the exhaust manifold, but I guess it has new gasket sealant between the turbo and the manifold and probably oil and grease from dirty hands on there as well
Adam_NAclubman
Adam's Clubman
Postby Adam_NAclubman » Wed Oct 28, 2009 1:44 pm
Hoping to get the Autronic in this evening before it gets dark
Adam_NAclubman
Adam's Clubman
Postby Adam_NAclubman » Sat Oct 31, 2009 11:17 am
Got it running on the Autronic the other day. Just need to chase down an oil seep and a coolant drip (both verrrrry slow) and then I just need a new exhaust and its good to go
Adam_NAclubman
Adam's Clubman
Postby Adam_NAclubman » Mon Nov 23, 2009 11:17 pm
Thought I'd gotten rid of the leak but then it appeared to come back. Now has a 2.5 inch exhaust with a highflow cat and a straight-through muffler
Adam's Clubman
Postby Okibi » Tue Nov 24, 2009 12:58 am
Congrats Adam, it must have really transformed the car.
Adam_NAclubman
Adam's Clubman
Postby Adam_NAclubman » Sat Nov 28, 2009 2:15 am
I really can't tell atm, it has 3/4 of a tank of 95 octane from before I cooked the old engine with half a bottle of octane booster in it atm, I need to get rid of that and put a fresh tank of 98 octane in before I can get the afr checked and any changes needed made to the tune. Not giving it too much load until then.
I drove it home tonight after finally getting my housemate to move his camper trailer so I can get my car under the carport again, temp gauge didn't go over half but I need to check the idle and timing I think, it was idling a bit low when warm and sounded like the rougher engine vibrations were making something resonate.
I did notice that something seems to be catching the front left wheel on right turns and it didn't do that before. Cooler piping is well out of the way, might have to get it on stands to have a look
Adam_NAclubman
Adam's Clubman
Postby Adam_NAclubman » Mon Nov 30, 2009 6:23 pm
I got the wheel alignment done today and had them raise the coilovers to minimum legal height, it still looks quite low though, and lower at the back than the front...
Booked it in for a tune on the 16th and ordered a Walbro from Mania, so hopefully I should have that fitted before the tune. Just going to leave the stock injectors in it and have the tune checked and tidied for low boost as I want to look into seeing if I can get it to pass the emissions test like Bark's car before putting the big injectors in and winding in some more boost.
I'm pretty happy with it atm, definitely going to take the NA BD bar out though, I cant see anything with the interior mirror
rossint
Adam's Clubman
Postby rossint » Mon Nov 30, 2009 8:05 pm
My car sits slightly lower at the back, was that way when I got it (tein struts and springs) I quizzed the guy who did my alignment about changing the perch height at the back and he said it makes it a bit more stable under brakes and was fine.
Adam_NAclubman
Adam's Clubman
Postby Adam_NAclubman » Tue Dec 01, 2009 12:28 am
Ah, that kind of makes sense. I still think its too low at the back though, too much camber
Adam_NAclubman
Adam's Clubman
Postby Adam_NAclubman » Thu Dec 10, 2009 11:44 pm
Installed a Walbro pump tonight, isnt as noisy as I'd expected
Adam_NAclubman
Adam's Clubman
Postby Adam_NAclubman » Wed Dec 16, 2009 5:41 pm
Had it tuned today to ensure its a safe tune on stock injectors. 6psi with a Walbro pump
I'm happy with that, it made 69rwkw there when it was stock
bark
Adam's Clubman
Postby bark » Wed Dec 23, 2009 4:40 pm
Adam, that is a great gain in power over your std 69rwkw!!
Just a word of caution with the RX7 injectors (which I'm sure your probably aware of) is that they will probably wash your bores and lead to premature engine failure due to the different spray pattern of a piston injector. I have found a great supplier of injectors in the US for piston spray patterns and you can choose what cc's you want. For example 440's were USD$50ea (BNIB) and 550's were USD$60ea and shipping was a flat rate of USD$40. http://www.eficomponents.com
Let me know if you would like to know more about emissions testing etc...
Sounds like we may need to go on a SA run somewhere soon...
