OMX-596 - 1996 Spec'd NA6 - Updated 21 Apr 2013
OMX-596 - 1996 Spec'd NA6 - Updated 28/12/2008
Postby Okibi » Mon Jan 05, 2009 12:31 am
Nice work, wish I had a hoist :mrgreen:
Postby Hammer » Mon Jan 05, 2009 1:06 am
Okibi wrote:Nice work, wish I had a hoist :mrgreen:
I wish I had the know-how :mrgreen:
Postby orx626 » Mon Jan 05, 2009 11:16 pm
93_Clubman wrote:Very nice Danny - sounds like a job for the M45...
Indeed! :twisted:
OMX-596 - 1996 Spec'd NA6 - Updated 24 Jan 2008
Postby orx626 » Sat Jan 24, 2009 11:07 pm
Well the JR M45, Megsquirt PNP, Innovate LC-1, KnocksenseMS and ARE radiator install got underway today in extreme climatic conditions...those of you from Brisbane will know what I mean. :shock:
With the MS I'm ditching the factory AFM and going with the MS MAP and air temp sensors. For ease I positioned the air temp sensor in the dummy throttle body.
Hole drilled for the tapped boss to be welded in.
Tapped boss in position.
Engine bay prior to diassembly...
Removal of the radiator...
Removal of the throttle body...
Installation of the dummy throttle body and replacement of the aluminium pulley with the original item to ensure that the supercharger is dríven at the required speed. If anyone wants the aluminium pulley just PM me...$30 plus postage.
Installation of the belt tensioner assembly...this is another unit...not the standard JR offering...it replaces the standard power steering tensioner assembly.
This is the extension loom for the throttle position sensor...as the throttle body is relocated upstream of the supercharger.
The throttle body mounted on the supercharger.
As far as the mechanical installation is concerned, there is not a whole lot left to do....however I do need to make a heat shield of some description to go between the supercharger and the extractors. I continued on and completed the mechanical install just to be sure I had everything. Here is what it looks like. The factory AFM is only there as an adaptor to get the engine going...will need to make a tube to replace it.
As you can see I haven't attacked much of the electrical work....that is what the remainder of the Australia Day long weekend is for. :mrgreen:
Obviously the radiator has to go back in as well...this will be the first job of the morning.
ps. I hope tomorrow is not 33 deg with a humidity of over 90% :x
graemebc
OMX-596 - 1996 Spec'd NA6 - Updated 24 Jan 2009
Postby graemebc » Sun Jan 25, 2009 12:12 am
Think you might have to put up with the heat again, Richo was sweating and not looking the best when I saw him today :frown: 33 degrees and battling a wog ain't much fun.
If its any consolation I will be sweating installing that torque box roll bar I bought off him :lol:
Looking forward to seeing this beast running, it will be excellent to finally see a supercharger mx5 in the flesh.
Incidentally are you going to do a coolant reroute? After speaking to Richard and doing some research on temp testing it seems it would be a worthwhile mod especially in giving a more even temp range across all the cylinders.
Postby Okibi » Sun Jan 25, 2009 4:56 am
Please please put some sorta intercooler on her and an upgraded radiator.
Since you have teh mad skillz how about a part radiator part cooler (for water/air cooling) to replace that poo brown radiator?
graemebc
Postby graemebc » Sun Jan 25, 2009 8:06 am
Did he not say he was fitting an ARE radiator as well Okibi?
CapitalF
Postby CapitalF » Sun Jan 25, 2009 10:22 am
Danny - it's lookin great! I'm green with envy of all that power.
Can certainly empathise re working yesterday - I installed the new clutch and lightened flywheel. A real bugger of a job when you are doing it on short stands, wearing glasses & sweating like a pig, in a small shed!
Peter
90 Silver Roadster 1.6 + GT2554, large IC, MS-PNP, lightened flywheel, HD Clutch, 2.5" exh, Teins, Whiteline, etc etc
Postby Okibi » Sun Jan 25, 2009 2:00 pm
graemebc wrote:Did he not say he was fitting an ARE radiator as well Okibi?
Yes you are correct very observant, MX-5 mods are like pr0n to me, I like the pretty pictures :mrgreen:
Postby Hammer » Sun Jan 25, 2009 2:07 pm
Looks like it's coming along nicely.
Fatty
Postby Fatty » Sun Jan 25, 2009 2:11 pm
yes but that doesn't actually address your initial comment about the intercooler.
danny is there going to be a ARE water to air intercooler fitted, to replace that standard cross pipe?
it's looking really nice so far 8)
Postby 93_Clubman » Sun Jan 25, 2009 2:13 pm
Fantastic Danny - can't wait to read & see more about the install & development - I think the M45 is underestimated, although admittedly it requires going the extra mile & has a lower potential ceiling than the MP62.
16bit
Vehicle: NB8A - Supercharged
Postby 16bit » Sun Jan 25, 2009 10:17 pm
I am pretty sure danny designed/co designed the pwr water to air intercoolers. I would think he would be doing his own version specific to this car.
Postby orx626 » Sun Jan 25, 2009 10:43 pm
16bit wrote:I am pretty sure danny designed/co designed the pwr water to air intercoolers. I would think he would be doing his own version specific to this car.
PWR's opposition actually James :lol: ... I've done a fair bit of R & D for Aluminium Radiators and Engineering (ARE) at Brendale in Brisbane... hence you see a lot of their handy work on my vehicles...especially the 626. I'll talk more about the IC plans for this car a bit further down the track. The main focus at the moment is to get it up and running so I can make it to the first club track day of the year in early March.
16bit
Postby 16bit » Sun Jan 25, 2009 10:53 pm
damn i was close though
Users browsing this forum: No registered users and 208 guests
