itrungs wrote:Maybe you can trick the cops by putting something like GRANNY LOLOLOL ... jokes
I know a guy who (with a combo of letters and numbers) has GUILTY as his plates. Needless to say he's lost a LOT of points from his licence...
charlie_91 wrote:So to try and get something that will read out everything and have an analog tacho i found the STACK cluster. it will display speed, tacho, boost, oil pressure, oil temp, water temp, voltage and also has a lap timer built in.. The beauty with this cluster is that its all standalone so makes it easy to install Also being able to display 4 readings at once and with a button to flick through makes it a lot easier and safer for me to know whats going on.
charlie_91 wrote:Hey mate. Yeah car will be all ready to go. Manifold and rear housing are just getting coated now so one I fit that, flip the tires, wing back on and it's ready to go
gslender wrote:charlie_91 wrote:Hey mate. Yeah car will be all ready to go. Manifold and rear housing are just getting coated now so one I fit that, flip the tires, wing back on and it's ready to go
Hey Charlie, have you done any back to back testing of the wing? Does it really make any difference to the rear end grip through corners? What speed do you need to be going for it to have any improved grip?
G
gslender wrote:Was just wondering that if it had an effect, it would also cause tremendous drag, but with sh*t loads of power (aka F1 cars) then grip is the issue, not power. Do you think the always drag is worth the sometimes extra grip? Eg. You might be quicker round the track without it!
G
Users browsing this forum: No registered users and 26 guests
