D.A.M's NA6
D.A.M
Re: D.A.M's NA6
Postby D.A.M » Mon Apr 27, 2015 3:24 pm
Update!
car is running perfectly with the help of Jelzahar and my good friend Brett. Replaced the Master and Slave cylinders today and its all good again 8)
White 1993 NA6
viewtopic.php?f=57&t=57652
Lakeside: 1:09
D.A.M
Re: D.A.M's NA6
Postby D.A.M » Mon Apr 27, 2015 5:11 pm
Only issue I've found thus far is, as i drive and hit about 2500-3000rpm the clutch pedal will vibrate a bit. Other than that its all fine. Is this an issue i should worry about?
White 1993 NA6
Lakeside: 1:09
D.A.M
Re: D.A.M's NA6
Postby D.A.M » Wed Apr 29, 2015 5:05 pm
ok so the T.O bearing was sitting on the pressure plate, luckily i had another genuine Mazda T.O and swapped that in (so the gearbox had to come out..again) and there is still vibration in the pedal but not as much which helps. After research its either the lightweight flywheel causing some vibration or the clutch bedding itself.
But overall, the car drives fine and the new 4.1 Torsen T1 diff feels amazing compared to the standard NA6 4.3 open center diff.
White 1993 NA6
Lakeside: 1:09
slug_dub
Re: D.A.M's NA6
Postby slug_dub » Wed Apr 29, 2015 5:52 pm
Is all that gearbox removal going on on the ground?? Thats a lot of removals in a short space of time :(
D.A.M
Re: D.A.M's NA6
Postby D.A.M » Wed Apr 29, 2015 6:22 pm
First one on Anzac Day was in a pit with the help of 3 other gents. Todays was on the ground with Jamal (champ). can officially say it was an experience and a half and we agreed its all part of the fun 8)
White 1993 NA6
Lakeside: 1:09
D.A.M
Re: D.A.M's NA6
Postby D.A.M » Mon May 18, 2015 1:02 am
From Downshift today with Brett Droder, photo was taken by MBF Productions
Also got in at the start of this video :D
https://www.youtube.com/watch?v=bVx5oj8xJ6s
White 1993 NA6
Lakeside: 1:09
D.A.M
Re: D.A.M's NA6
Postby D.A.M » Fri Jul 17, 2015 8:45 pm
Acquired a 24mm adjustable Superpro front anti sway bar and SuperPro bushes to aid the handling compared to the old stock bar and bushes
White 1993 NA6
Lakeside: 1:09
D.A.M
Re: D.A.M's NA6
Postby D.A.M » Fri Aug 21, 2015 1:13 am
New update of late, about 80% of the time when slowing to a stop, the cars revs wont stop at 800-900 region but dip down to about 100-200 revs and jump back up to the good idle rev range of 900 ish revs. sometimes if i clutch in a a specific time the car will stall.
otherwise runs well as per usual.
must investigate but guessing there is an air leak happening somewhere as Nitro Dann mentioned in another thread regarding some odd readings my air/fuel ratio gauge was giving me.
Will update soon with progress reports. 8)
White 1993 NA6
Lakeside: 1:09
D.A.M
Re: D.A.M's NA6
Postby D.A.M » Sun Nov 01, 2015 9:27 pm
fixed the above issue as there was an air leak in the intake! so runs great now
White 1993 NA6
Lakeside: 1:09
D.A.M
Re: D.A.M's NA6
Postby D.A.M » Sun Nov 01, 2015 9:30 pm
Today Kirk and Jelzahar helped with a major service including the Timing Kit and Water Pump.
Some pics as follows:
the Superpro 24mm adjustable sway bar
Finding top dead center
White 1993 NA6
Lakeside: 1:09
D.A.M
Re: D.A.M's NA6
Postby D.A.M » Mon Nov 02, 2015 11:14 am
Another last minute purchase are the OE-Style 1028 Mirrors, they're very light, bit smaller then the stock NA6 ones and look cool, Tinted blue as well to help with vision.
The only issue is they're a bit smaller compared to the stocks so it can be trickier to see whats going on behind you.
White 1993 NA6
Lakeside: 1:09
slug_dub
Re: D.A.M's NA6
Postby slug_dub » Mon Nov 02, 2015 11:50 am
Photo fail here Dion :lol:
D.A.M
Re: D.A.M's NA6
Postby D.A.M » Mon Nov 02, 2015 2:20 pm
ok for some reason its showing perfect on my oc, but its not showing on my phone, will try and fix this
White 1993 NA6
Lakeside: 1:09
D.A.M
Re: D.A.M's NA6
Postby D.A.M » Mon Nov 02, 2015 2:26 pm
Finding Top Dead Center
and the new OE - Style 1028 Mirrors
White 1993 NA6
Lakeside: 1:09
D.A.M
Re: D.A.M's NA6
Postby D.A.M » Thu Nov 12, 2015 7:34 pm
The Achilles ATR Sport tyres are off and brand new Federal 595RS-R's in the 195/50R15 size are on, just in time for the QLD MX5 club track day at Lakeside too.
Must admit the ATR's are a cheap tyre for a bit of fun, but the 123's I had previously were definitely better, although overall after a few mountain runs, the Federal's are the top pick.
White 1993 NA6
Lakeside: 1:09
