Shuey's 2001 NB8B "Sparky Mk II"
shuey
Re: Shuey's 2001 NB8B "Sparky Mk II"
Postby shuey » Sat Sep 07, 2013 2:24 pm
Okay, for starters.. I managed to remove the rounded off bolt (thanks for the tip KevGoat) and fixed on the fire extinguisher. Had to drill another hole into the metal plate as the bracket hole was not the same, but no biggie
Tadaa!
A few days later on, noted that MX5 Parts UK came along and decided to have a 10% sale, so decided to throw a little money into the aesthetics of the car. This time some clear reflectors and repeaters. Seems cheaper than buying locally, so what the heck.
As usual, tops for shipping. Order to door in a week's time (inclusive the weekend). Side repeaters and clear reflectors for approx. $103 landed
Clear reflectors came with amber bulbs, but needed only the reflectors. Side reflectors were OEM Mazda, slightly more expensive than the "budget" ones..but only quality for me
Removal was easy, just take your trusty credit/loyalty card..wedge the clip (on the left hand side), and it'll pop out. Turn the grey housing counter-clockwise to remove repeater and housing. Then just pull out the clear bulb. Replace with the amber bulb supplied and reverse the steps. All done in 1 minute
Love my glossy RE002 8) . No intelligence needed for the reflectors, just your normal screw driver and you're good to go
Sits pretty flush.. quite nice, I like
Rear quarter view
And finally, the comparison..... :wink:
Before
After :mrgreen:
shuey
Postby shuey » Sat Sep 07, 2013 7:34 pm
Update, Part Deux;
.. after having the chat with the other guys and not wanting to have the softie tag been labeled against me, I decided to toughen the fvck up (that is after a couple cans of Monster energy drinks) and try again with the SE exhaust.
Weather was pleasant today, so that helped with the visibility. After picking up a few tips and kebab last Thursday night, I decided to use the screwdriver method and lotsa soapy water to loosen the rubber hanger mounts. There were 3 rubber hanger mounts; 1 near the 2 bolts (LHS) and 2 at the RHS. I've been reading alot and ppl have advised to work on the RHS ones first and once you get that done, since the exhaust will start to sag.. put a cardboard underneath the muffler to keep it level, so you could work on the LHS one without trying to juggle it with your feet (the trolley jack works too, but I was still using the jack as a emergency safety net should for any reason my jack stand collapse)
Basically this was what I did
1. Use a flathead screw driver and wedge a gap between the hanger and rubber creating a hole
2. Spray dishwashing liquid for lubrication.
3. Start peeling and wiggling the rubber mounts off the metal hangers (With the screwdriver still in there) till the metal knob goes through.
4. After that, easy peasy.
5. LHS one was a bit tricky as the flange was in the way. I unbolted the 2 bolts and let it hung a little before doing the same and removing the metal hanger off the rubber mount.
Bolting the new (old) exhaust wasn't that hard.
1. Place muffler on the cardboard box or jack to keep it level (or if u have a mate to hold it up, that's fine too)
2. Attach the muffler to the flange and loosely screw it in place.
3. Insert the LHS exhaust hanger into the rubber mount
4. Insert the RHS exhaust hangers into the rubber mount (I do the LHS one first) cos I needed the exhaust to still be a little flexible to fit it on cos once you put on the RHS one it's gonna be more rigid hence making it a bit harder.
5. Tighten bolts and good to go
Tools:
1. 1,800 kg trolley stand
2. 2x 1,200 kg jack stand
3. 17mm socket and ratchet
4. Morning fresh dishwashing liquid and/or WD40
5. Torchlight
6. Cloth
7. 2x can of Monster energy drink
8. Some upper body strength
.. if you might be wondering, that light at the left rear tyre is my flashlight
Jack stand box and a small tool were useful to hold the muffler in place and just about the right height
Side by side comparison. Direct bolt on, SE outlet and tip a bit longer
Slightly droopy, to accommodate the SE bumper lip. But I'll sort that out once I find a lip too :wink:
Bye bye baloney standard muffler
.. and hello shiny chrome Mazdaspeed
I did give the muffler a good clean to get rid of almost 10 years of crap. Not shiny, but still nice
First impression? No difference in sound at idle.
At high RPM, a slightly raspier and throatier sound (go fast sound) which I like so the missus won't know :mrgreen:
Not sure if there were any gains, but if there were any it would be negligible at best. But since I got it for a bargain and aesthetics and sound were good, I'm a happy camper
Postby KevGoat » Sat Sep 07, 2013 8:18 pm
shuey wrote:Slightly droopy, to accommodate the SE bumper lip. But I'll sort that out once I find a lip too :wink:
... "find a lip" ... me first this time Scott :mrgreen:
I keep looking for one of those SE lower rear lips but they're rarer than the rear SE boot spoiler!!
Great job on the exhaust mate. Will be interested to hear what you think of it over a period of time. I'm missing the sound of my NA's system ... but loathe to spend as much as I did on that ...
Clear reflectors/indicators look great. Really suit your's. Have you wired the front/rear reflectors?
meanmx
Postby meanmx » Sat Sep 07, 2013 9:53 pm
I'm so proud of you. It's like when your kid learns to go to the toilet for the first time :mrgreen: . What's next now that you are becoming a master of the mechanical bits? Rebuild engine? Looks awesome mate although at this rate you should of just bought an SE
2014 VW Mk7 Golf R
Postby KevGoat » Sat Sep 07, 2013 10:14 pm
meanmx wrote: ... although at this rate you should of just bought an SE
... haha ... him & me both :mrgreen:
shuey
Postby shuey » Sat Sep 07, 2013 11:38 pm
KevGoat wrote:... "find a lip" ... me first this time Scott :mrgreen:
.. yeah, I think it's gonna be hard to find an SE bumper lip.. so may look at alternatives in the future.
I'll keep the SE exhaust until something else nicer pops up..haha! Pretty subtle to be honest
At this stage don't intend to wire the reflectors up, but will have a look at them since I've got the bulbs already
meanmx wrote:I'm so proud of you. It's like when your kid learns to go to the toilet for the first time :mrgreen: . What's next now that you are becoming a master of the mechanical bits? Rebuild engine? Looks awesome mate although at this rate you should of just bought an SE
Thanks, meanmx! :mrgreen:
Yea, I did spot an SE a couple months after I got mine but alas but bad timing I guess. Anyhow non-SEs are still cheaper to run anyway..
Still got a few items on the list to be done, will try to see if I can find some bargain bits when I fly back to KL. :wink:
Postby Okibi » Sun Sep 08, 2013 1:13 am
I have a spare SE bumper lip somewhere.
shuey
Postby shuey » Sun Sep 08, 2013 2:02 am
Okibi wrote:I have a spare SE bumper lip somewhere.
Let me know if you do find it :wink: , say how's it fitted onto the bumper?
Postby KevGoat » Sun Sep 08, 2013 11:34 am
That works out timely Scott ... you could have it painted & fitted at same time as sideskirts :grin:
speed freak
Postby speed freak » Sun Sep 08, 2013 8:08 pm
How did you fasten the fire extinguisher bracket to the metal plate, screws or pop rivet or something else? Im wanting to mount mine soon just bought the extinguisher on the weekend.
Your mx looks great too.
Postby Okibi » Mon Sep 09, 2013 12:00 am
Bolts.
narita
Postby narita » Mon Sep 09, 2013 12:28 pm
thanks for making me want clear bits :( :NETPOINTZ:
WINTON PB - 1:57.4000
Aussie Stig
Stig
Postby Aussie Stig » Mon Sep 09, 2013 6:35 pm
Thanks for letting us know about the SE muffler on a n/a car, sounds pretty underwhelming. :frown: :frown:
shuey
Postby shuey » Mon Sep 09, 2013 7:54 pm
narita wrote:thanks for making me want clear bits :( :NETPOINTZ:
.. you know you want to get some now, Brett. :mrgreen: It's subtle but definitely complements the color, IMHO.
Aussie Stig wrote:Thanks for letting us know about the SE muffler on a n/a car, sounds pretty underwhelming. :frown: :frown:
I'll try to put up a sound clip one of these days. If you are expecting something like the RB Power Pulse base-y drone, then you will be underwhelmed but if you can get hold of one for a bargain it's still heaps better than the stock one, even if its just looks. $50, MSM chrome tip & a little raspy = win! :wink:
MadMikey
Postby MadMikey » Wed Sep 11, 2013 4:51 am
Looking good Shuey!
