timk makes up for talent with an EFR
Re: saboteur's NB
Postby orx626 » Thu Aug 02, 2012 11:45 pm
saboteur wrote:The engine will be started later this afternoon! :D
The engine was started this afternoon! :mrgreen:
timk
Re: saboteur's NB
Postby timk » Sat Aug 04, 2012 11:13 pm
The car is back home now and everything seems to be working as expected!
orx626 wrote:The engine was started this afternoon! :mrgreen:
Huge thanks to Automotive Plus for their efforts and top quality workmanship.
Now I just need to finish the engine run in procedure then hit the dyno! 8)
TieNN89
Re: saboteur's NB
Postby TieNN89 » Sun Aug 05, 2012 2:06 am
w00 h000!!!!
Guran
Vehicle: ND - 1.5
Re: saboteur's NB
Postby Guran » Wed Aug 15, 2012 1:20 pm
Was wondering who this new moderator "timk" was? :? Then I realised ... formerly known as "saboteur". 8)
timk
Re: saboteur's NB
Postby timk » Wed Aug 15, 2012 2:05 pm
Yeah, I decided it was time to grow up! :P
I should put that in my signature.
timk
Re: saboteur's NB
Postby timk » Fri Aug 17, 2012 11:08 pm
The car has been great, and no issues except for the battery going flat. I have put over 500km on the new engine now, so it's getting close to tuning time. Kudos again to Jason and Automotive Plus!
I'm waiting on a BEGi throttle body inlet to replace the rubber item I have at the moment, then I will get some engine bay pics uploaded! :D
jerrah
Re: saboteur's NB
Postby jerrah » Fri Aug 24, 2012 4:21 pm
On another thread you mentioned you haven't taken the SE engine past 10psi as you're running it in. What is your goal PSI/HP wise?
My car is tuned for 14psi but I've found 10psi is enough unless it's a special occasion. 8)
1991 MX5
timk
Re: saboteur's NB
Postby timk » Sun Sep 16, 2012 1:38 am
Been a while since my last update but fortunately there hasn't been much to report as far as the new engine goes!
I had to replace the clutch master cylinder as it was leaking, as well as the alternator. I also had 3 of the 4 bolts shear off holding the harmonic balancer:
Fortunately this happened while I was driving slowly up my street so I could stop it straight away! :shock:
The car has now been tuned, although I haven't yet got anything to control boost so it was just tuned at the wastegate setting. It made 127kw at 8 psi.
First track day is on Monday, can't wait!
chefie
Re: saboteur's NB
Postby chefie » Sat Oct 13, 2012 11:47 am
Hi Tim
i am looking at a set of Tein SS on the forum,i noticed you have the same coil over are your teins a 6kg front and 5kg rear and are you happy as a street track set up
Thanks
Jaime
98 NB8A Grace Green
LS 66.17,QR Club 69.27, QRSpr 63.58 SOLD
01 NB8B Grace Green
LS 64.66,QRNat 1.31.94,QR Club 65.17 QRSpr 62.36
93 NA8 Clubman
timk
Re: saboteur's NB
Postby timk » Tue Jan 22, 2013 11:27 am
Jaime, yes mine are a 6/5kg set. They are good for a mostly street & occasional track car, but they dive a bit under really heavy braking.
Track day was good fun, still running wastegate pressure:
The oil temps got up to 110c/230f on the track, so I've got a Flyin' Miata oil cooler kit on the way, hopefully this will take the edge off the temp.
Here's the engine bay as it currently stands:
I've fitted the boost control solenoid behind the AEM heat shield, seems to work nicely here:
Once the oil cooler kit is in, hopefully I'll be able to run ALLOFIT boost! :lol:
mx5002
Re: saboteur's NB
Postby mx5002 » Sat Feb 02, 2013 9:36 am
nice build up on the car mate.
Whats with the iphone on the windscreen in the video?
was it timing your laps?
GREEN ITB'd NB8B
Marulan 47.01
Wakefield 1.09.64 :D
timk
Re: saboteur's NB
Postby timk » Sat Feb 02, 2013 3:36 pm
Thanks mate. Yeah I am using an app called Harry's Lap Timer Pro, it's worth checking out.
gslender
Re: saboteur's NB
Postby gslender » Sat Feb 02, 2013 5:38 pm
Looks good... What ecu do you run?
G
mx5002
Re: saboteur's NB
Postby mx5002 » Sat Feb 02, 2013 9:09 pm
sounds good,
i wonder if they have an android equivalent. :|
GREEN ITB'd NB8B
Marulan 47.01
Re: saboteur's NB
Postby Crapweasel » Sat Feb 02, 2013 9:15 pm
mx5002 wrote:sounds good,
We wish. iOS is easier to code for due to uniform screen sizes (amongst other things or so I've read) so unfortunately the better selling platform misses out for a while.
Users browsing this forum: No registered users and 385 guests
