Andrew's 1994 Clubman (ex Fuzzlet)
daffyflyer
Postby daffyflyer » Tue Oct 06, 2009 9:53 am
Yeeaaaa.... it kinda broke its motor..
This one was half my fault, bit of crap in the bearings when i built it i think.
But also a few things already screwed like the bores worn, and the timing idler pulleys sound like they have sand in them... looks like it was a bit of a special motor even before i got to it lol :P
Anyway, carco is now working magic on it, and it should be properly good after that (with a few enhancments, will tell all when its decided :mrgreen: )
Developing a Car Industry Game - Visit www.automationgame.com
White 1994 MX5 Clubman - Carco Built NA Motor - 101kw ATW @ 7500rpm
Postby Jeo » Tue Oct 06, 2009 10:00 am
I saw it there the other day...
Boags
Postby Boags » Tue Oct 06, 2009 10:47 am
How did that happen? Wasn't this a new engine build a few months ago?? Did you rebuild it in a sand pit? :?
daffyflyer
Postby daffyflyer » Tue Oct 06, 2009 2:46 pm
Boags wrote:How did that happen? Wasn't this a new engine build a few months ago?? Did you rebuild it in a sand pit? :?
Errr.. yeah, dunno really, it looked clean as when i was building it, but a bearing was scored to sh*t.
Also leaked oil due to a broken bolt...
Yeah, it was a bit of a special build (due to the special builder lol)
Also the bores have been buggered since before i owned it, even though it had been recently rebuilt before that, this damn engine is cursed i tells you!
Decided i never wanted to have to worry about the motor again, so it shall be done properly
So most likely a stock rebuild + Porting, Valve unshrouding, balencing, flywheel lightening, nicer clutch, adjustable cam gears :)
daffyflyer
Postby daffyflyer » Tue Oct 06, 2009 2:53 pm
Also thankfully not much money wasted - only the bearings, gaskets and rings i guess - crank is still OK, and rods would survive a nuke :)
Big waste of time, but live and learn, was still interesting!
daffyflyer
Postby daffyflyer » Sat Oct 17, 2009 4:13 pm
Yay! car done, russell builds a good motor, its punch, loves to rev and is very smooth :D
Postby Jeo » Wed Apr 14, 2010 11:45 pm
Intake fit yet?
daffyflyer
Postby daffyflyer » Wed Apr 14, 2010 11:47 pm
Nope, doesn't fit, never will with my setup it seems, left it at russels, you can have it back if you want
daffyflyer
Postby daffyflyer » Sun Apr 18, 2010 10:06 am
Just did a bit of intersting math..
If my NA8 makes 101kw ATW, and Hammers makes 76kw ATW, then that should mean mine has approx 122kw @ 7500rpm
122/7500 X 9549 = 155nm @ 7500, which in theory means my motor now makes as much torque at 7500rpm as a stock one does at peak torque :mrgreen:
Dunno if im right, but if so, thats a gain im pretty happy with, it sure FEELS that quick! :)
daffyflyer
Postby daffyflyer » Sun Apr 18, 2010 10:12 am
And if thats true, I wonder how peak torque is and where it is... will have to track down the dyno sheet or grab a copy off russell
