charlie's na6
- NitroDann
Re: charlie's na6
Went back and pooked at pics, its not draining, that -8 fitting just isnt big enough to drain both turbo and catch can fluid, infact the turbo might be pushing oil up into the catch can.
Do you have stock breathers/pcv?
If so you need to weld larger breathers to the cam cover, locate the catch can to the drivers side and drain into the stock GTX catch can drain hole.
Re: charlie's na6
Heres a quick vid from the track.
Warning: it does get shaky at times but atleast u get an idea haha Ill have an in car vid soonish.. Just gotta go get it off my mate
http://www.youtube.com/watch?v=34aB6AUoPQw&list=UUqWwfvuyKn8Jw7z_V0EIoGw&index=1&feature=plcp
- NitroDann
Re: charlie's na6
Smashed that twin cam Excel!
- 16bit
Re: charlie's na6
you may want to get into third coming out of the last corner with all the torque you will have, or at least give it a go.
sounds pretty damn nice.
Re: charlie's na6
That's actually topping 3rd shift 4th on exit
- 16bit
Re: charlie's na6
bloody nora!!!!
- orx626
- Vehicle: NC - Rotary
Re: charlie's na6
16bit wrote:bloody nora!!!!
IIRC it is a 6-speed gearbox coupled with a 4.3 Torsen James!
- zero00
Re: charlie's na6
Charlie91
Lakeside is Monday 23 July next - love to see you there and also if Danny can get the afternoon off as well!!
Nice video, sounds great!
Roger D-SUNSHINE COAST
Re: charlie's na6
I would t mind trying lakeside. Have to see how I'm going on funds
Update:
So since Sunday we've been trying to find out whats wrong with the breather setup.
We took the valve cover off yesterday to see what's up and found a few things. Ok so the valve cover is ceramic coated inside and out, so the inside of the cover has like a slippery coating. When we stated to disassemble the baffles (take the covers off) it seemed that because of this coating the sealant wasn't t able to bond properly meanin it probably wasn't sealing all round. This is the first problem.
Once all the covers were off we started looking what's going on and found something strange. When I got the cover Coated, they put it in a big polisher machine (machine that vibrates millions of tiny ceramic balls to polish). When I got the cover I had to remove all the balls that were stuck in the gaps.
Between the middle baffle and the baffle where the -10 weld on is situated is linked by a tiny passage to let oil through. The oil is allowed to come through the middle baffle via a trap door type thing and then the only way to get to the problem baffle is via the passage. However, blocking this passage was a ceramic ball lol. So no oil was able to get through.
And it seems that the only way the oil could get through is under the unsealed covers. Imagine it like this, down the straights at 7000rpm, the motor would be flicking oil like crazy under the cover allowing a lot of oil to get into the baffle.. Turn one is around 150-160kmph and before it's got a chance to drain back through the oil is sucked out of the baffle into the catch can giving us the problem.
So in theory if we seal this up proper, there shouldn't be the same problem. So we sanded away the coating exposing the bare metal, flattened allege covers and sealed it all up again. Having done this it 'should' solve the ƒü¢k ton of oil gettin out in turn fixing my breather problems.
One thing i wanted to rule out was anything wrong with the bottom end so we put it under a compression test and results showed 165 across all 4 very happy to know that.
So having sealed up the cover properly, I'm also moving the catch can up higher and making a bigger tank to sit in the top right hand corner.
Hopefully this fixes it all. It all makes sense so we'll soon see
Update:
- 16bit
Re: charlie's na6
orx626 wrote:16bit wrote:bloody nora!!!!
that would make sense!
- Vehicle: NA6 - Turbo
Re: charlie's na6
Hey Charlie, what sort of oil temps are you seeing on the track?
http://www.facebook.com/purefabcustom
EFR6758 run-in tune 259hp atw on 10psi pump 98 dyno dynamics
E85 tune - 445hp @ wheels 17psi
Re: charlie's na6
Oil temps rarely get to 110 but never go over after a full session.
Re: charlie's na6
Hey guys,
Not much to update. but i sold my old mirrors and got my new mirrors the other day
Heres some installed pics:
Figured out what setup we are doing for the breather so thats good. Should work fine And unfortunately my email that i sent to book the track day didnt send and now its booked out so i dont think i will be racing then.. Theres another day at Lakeside on the 16th but i didnt really wanna go to this track so early.. Oh well lol
Any track time is good track time.
Re: charlie's na6
Oil tens are very good, ill have to check out your previous pages to see what you've done for the oil cooling setup. Car is looking good too
Re: charlie's na6
Update:
So finally some in car footage of the first session. First time back out there with more power so took a little to get back into it. Still can see a lot of places i can improve so thats good. After seeing the incar of some of my mates and the line/braking points that they take it seems clear where i should go.
On the straight im in 5th and the reason i let off early is because im almost on limiter and i dont want to change to 6th for the split second. Here is where i think some 4.1 gears will do me good. Especially coming out of the last turn to. So that might be something to look into.
When you see me slow down around turn 2 thats where i can see smoke lol not so good, and then i forget to turn it off.
Next time will be better, session two feels like i got better and that was the quicker of the two laps so yeah. Can only improve from here
http://www.youtube.com/watch?v=SDnJSm9vE-0
comments welcome.
btw ƒü¢k it looks like i sit high.. i need some lower rails stat.
comments welcome.
