Guran's NA6 "Little Reddy"
Sailor
Re: Guran's NA6 "Little Reddy"
Postby Sailor » Thu Jun 14, 2012 4:24 pm
Heh heh...another drive of an NC might cement that decision :idea: :lol:
On another point, I really don't mind having the hares out in front of Mod NC.
I'm in it for the fun not the trophy and having Phil and Ralph up there to aim at is IMHO a good thing.
Rob
Hellmun
Postby Hellmun » Thu Jun 14, 2012 8:29 pm
If you want to be competitive at super sprints I'd go mod NA . Clubman will handi-cap you greatly due to no equivalent class. NC will do well right up until one of the many performance derived 2.0 cars comes and plays (As you've seen with Exige, S2000, Integra Type R, Civic Type R etc). Plus Tony Williams will keep getting faster... that car is quick, I was being super cautious driving it on the brakes the day I did 1:12:99 to ensure I didn't cause him a flatspot. I feel confident that car would do 11's easily... then eventually 10's.
If you'd enjoy modifying and re-learning to drive as the car evolves then NA will be fun and it's going to be competitive, as you've previously worked out there aren't many 1.6's that would overwhelm an Mx5. That said it won't be at the pointy end immediately...and it's a LOT of work making modified cars go forwards, even after you installed *upgrades* they often involve driver changes or setup changes. Plus there will be many compromises in race track use...really hard to get away from noise when you need good flow. Though that said how much fun did you have in my loud and overly stiff underpowered car :mrgreen: . Within the rules you could get more power out of the 1.6 engine than I had (Tony already does) so if you could get it to stop equivalently it should go fast..it should already corner faster due to less weight.
Otherwise get the NC, replace the plastic bits in the gearbox and go racing immediately and be competitive on both sides.... On the bright side you get a REALLY nice daily driver and it's a massive amount less work having the same adjustability you have now (alignment and tyres?). On the bad side as stated before it could be impossible annihilated by many other sports cars. The amount of books, research and analysis I did trying to get my car competitive with Rex Hodder was quite incredible.... but only got within 1.5s at it's best. You simply cannot beat a car that started at 800kg, has more power and gets better standard parts than you can modify to.
For me it would come down to whether you want to modify the car or not? Whether you want a quiet nice daily driver when it's not racing?
Guran
Vehicle: ND - 1.5
Postby Guran » Thu Jun 14, 2012 10:44 pm
Thanks for the advice Mark.
Hellmun wrote:For me it would come down to whether you want to modify the car or not? Whether you want a quiet nice daily driver when it's not racing?
Precisely! That's exactly the dilemma I'm battling with.
I'm still enjoying my standard car, and finding little improvements here and there. I like having a comfortable car for occasional street use and weekend drives. It will also be a big challenge to compete in Class 4 or 5 with a standard car, and that has strong appeal. What'll Mike do if I win Class 4 or 5? :lol:
On the other hand, there's the modified path. Tweaking my car with a selection of basic mods (Torsen, springs & shocks, headers, catback, intake) should deliver something that can do 1:12s at Wakefield, but it's a big ask to get into the 1:10s and be competitive against Jason's B16A Civic in the supersprints. Would need some serious work on the brakes and engine, just for starters. Getting expensive. And then it'd be a horrible thing for street use.
TBH, buying a used NC for track use is not really an option at the moment. Tempting as it is.
Definitely lots to think about ... :?
Hjt
Postby Hjt » Thu Jun 14, 2012 10:55 pm
Have you been trying or had any luck in moving on the 135i recently?
If you slowly move up the classes, setting records as you go, it would be interesting.
We all know, if you lower your car much, some of your apex points will need tweaking, or your front bar will be dríven over :D
PeterB
Postby PeterB » Thu Jun 14, 2012 11:21 pm
Bryan
With current fields, a mildy modified NA6 running in 5M (or clubman) for track days and 2A or 3A (whichever one the Civics are not running in) for state supersprints (quickest current 3A entrant is Chris Peterson with a mid 13 at WP, whereas the Civic in 2A is in 1.09) should leave you a car that is still nice to drive on the street.
If I was starting again I would do an lsd, cat back exhaust, adjustable swaybars and Koni yellow adjustable shocks with stock springs (running on the lower setting) and 15" rims for semis. This would make it eligible for clubman or modified and should get into 13s on semi-slicks, but still be a nice road car.
If you want to experience a mildly modified NA6, enter as 5M for the July trackday (you can give the R888s a run before PI) and you are welcome to drive my NA6 for a couple of sessions to see how it feels compared to yours and get an idea if you want to invest a little more into the NA6. If you put your logger in you could compare the two cars ?
Peter B
MX5 free for present
Guran
Vehicle: ND - 1.5
Postby Guran » Sat Jun 16, 2012 11:56 pm
Thanks for the feedback Peter. And yes I'd love to have a go in your car next time. However after much debate, I've decided that I'm going to continue with a standard car and enter Class 4 (clubman) at the club trackdays. Will also continue with 1B at the Supersprints and try to improve my 1A records while I'm at it. Doubt I'll win anything, but I'm still enjoying what I'm doing, still learning, and not quite ready for the change to modified. The variety of switching between S-specs and R-specs is also really fun.
PeterB
Postby PeterB » Sun Jun 17, 2012 5:44 pm
Clubman will be good as you will have a few cars to chase.
Your welcome to have a run in mine, so we can set it up with Mike on the day.
Peter B
tbro
Postby tbro » Sun Jun 17, 2012 6:28 pm
Hey Bryan!!
Mate, leave Little Reddy alone and run stock. Honestly once you start modifing a 1600 you'll spend mega dollars to achieve reasonable results.
I won't tell you how many hours were spent getting Scooter to produce horsepower but knowing what I know now DON'T even think about doing a 1600, its bloody expensive but a lot of fun (yer right!!!) The car did do a 1.58 at EC and finished the 1 hour so I suppose thats not bad but compared to the 1800 in him now chalk and cheese.
So have lots of fun and enjoy it.
Terry
BTW, noticed today that Scooter has done 122ks, that nearly 5 k since I got him :lol: :lol:
Guran
Vehicle: ND - 1.5
Postby Guran » Mon Jun 18, 2012 10:34 pm
Yeh, staying stock and continuing to enjoy it! 8)
1:58 at EC, eh Terry? Not bad :wink: . My stock NA6 has done 1:59.29. :P :lol: I've had a bit more practice there though ... and your 1:59 was on a damp track wasn't it?
Guran
Vehicle: ND - 1.5
Postby Guran » Fri Jul 13, 2012 9:04 pm
I just bit the bullet ... this afternoon I traded-in my BMW 135i and replaced it with a 2009 NC2 Roadster Coupe in Stormy Blue. Pretty bloody excited! :mrgreen: Say hello to Little Bluey. :lol:
IMG_1605 by Guran5, on Flickr
zero00
Postby zero00 » Fri Jul 13, 2012 9:30 pm
Guran
Congratulations!!! Well done!!
Welcome 'Little Bluey'! :wink: :beer: :NC:
Roger D-SUNSHINE COAST
Dweezle
Postby Dweezle » Fri Jul 13, 2012 9:32 pm
Ohhh !!!!!
Jealous much!! :mrgreen:
ALL MUSCLE CARS ARE CRAP
Jeremy Clarkson
Apu
Postby Apu » Fri Jul 13, 2012 9:50 pm
Haha! So we'll see little Bluey at the next track day?
Guran
Vehicle: ND - 1.5
Postby Guran » Fri Jul 13, 2012 9:53 pm
Thanks guys. Little Reddy will remain on track duty for now. The fun part is that now our whole family can go on club runs together and take two MX-5s. I could have had an 86 GT for about the same price it cost me ... but I didn't want another fixed-roof coupe. The folding hardtop NC is definitely what I was after, and the ND is looking like it'll be ages away now that Mazda have announced another facelift for the NC. So I finally decided to take the plunge and just do it. The car's got a few minor scratches and scrapes that need repairing (gave me haggle room on the trade), and then a quality detail should have it looking good as new. My head is still spinning at how fast this all happened! :lol:
Postby Regie » Fri Jul 13, 2012 10:12 pm
woo Bryan!!! nice work mate!!
Welcome to the NC club :P
Ill bring a spare cardigan down to the track day at the end of the month...
Does this mean we will be competing in the same class on the club days soon?? haha
