Daffy's SE
Re: Daffy's SE
Postby bruce » Mon Oct 28, 2019 2:57 pm
Any issue with the length of the leads (longer leads = more resistance)?
StuwieP
Re: Daffy's SE
Postby StuwieP » Mon Oct 28, 2019 10:07 pm
That's what I was thinking too. There would have to be some, but maybe it is offset by the benefit of reduced heat-related issues?
My NA6/SE build
Engine #1 RIP 04/07/2020
Daffy
Re: Daffy's SE
Postby Daffy » Wed Oct 30, 2019 7:46 am
bruce wrote:Any issue with the length of the leads (longer leads = more resistance)?
Only time will tell. They are a pretty powerful coil.
StuwieP wrote:That's what I was thinking too. There would have to be some, but maybe it is offset by the benefit of reduced heat-related issues?
The thought was to place them there with keeping operating temps in mind.
SKYHI wrote:Well I can't say I've ever seen coils mounted there before........but why not :)
Reasoning as mentioned above.
ManiacLachy wrote:Looks like a good location for it, clean install.
Thanks mate, Daz has a similar mount with MSD coils he’s mounted in a couple of WRX’s and they seem to work pretty well in that location.
At this stage most of the extra wiring is in, hopefully its down to the tuner before the week is out to have the dwell time set, just waiting on the new leads to arrive now :)
viewtopic.php?t=73496
16bit
Vehicle: NB8A - Supercharged
Re: Daffy's SE
Postby 16bit » Wed Oct 30, 2019 6:42 pm
those coils are twice as powerful as r35 gtr coils which would be more than sufficient for this build - so suspect any additional resistance from longer lines is entirely irrelevant. plenty of folks running 160 + whp per cylinder on r35 coils...
Daffy
Re: Daffy's SE
Postby Daffy » Thu Oct 31, 2019 6:39 pm
16bit wrote:those coils are twice as powerful as r35 gtr coils which would be more than sufficient for this build - so suspect any additional resistance from longer lines is entirely irrelevant. plenty of folks running 160 + whp per cylinder on r35 coils...
The new leads! I was hoping they would arrive today- so at this stage looks like next week to set the dwell time :DIY:
Daffy
Re: Daffy's SE
Postby Daffy » Fri Nov 15, 2019 3:30 pm
The new set up is almost all wired in and the 9mm Leads look good and the mounting location fits the coils well. The usual unexpected hold ups have seen things move a little slower anticipated, but the unexpected is always expected. So its off to have the dwell set in a couple of weeks, just in time for the upcoming dodgy day at Magpies :mrgreen:
ManiacLachy
Re: Daffy's SE
Postby ManiacLachy » Fri Nov 15, 2019 3:45 pm
Something about the angle those photos are taken at makes me dizzy!
The bracket is really neat tucked over there. Just need a nice tidy routing of the wires to finish it off.
I won't be a Magpie's but I'll try to catch up with you soon (once my car is back on the ground and running).
StanTheMan
Re: Daffy's SE
Postby StanTheMan » Fri Nov 15, 2019 3:48 pm
Setting the dwell. Isn’t that something that should take like 2 seconds? Or does the tuner have to test them because dwell settings for these coils have not been published?
Daffy
Re: Daffy's SE
Postby Daffy » Fri Nov 15, 2019 8:23 pm
ManiacLachy wrote:Something about the angle those photos are taken at makes me dizzy!
The bracket is really neat tucked over there. Just need a nice tidy routing of the wire catch up with you soon (once my car is back on the ground and running).
Cheers mate, that catch up should be on very soon :)
StanTheMan wrote:Setting the dwell. Isn’t that something that should take like 2 seconds? Or does the tuner have to test them because dwell settings for these coils have not been published
The old set up will still be in until I get it up to Matty. Daz is rigging it all up but Matty wants to be the one to plug it all in before setting the dwell- also we want to have a read of the power draw with this set up and tidy a couple of other little things mate. :DIY:
SKYHI
Re: Daffy's SE
Postby SKYHI » Mon Nov 18, 2019 1:30 pm
Looks good mate, well done. Keen to join in on the catch up too if possible :)
Daffy
Re: Daffy's SE
Postby Daffy » Wed Nov 20, 2019 6:00 pm
SKYHI wrote:Looks good mate, well done. Keen to join in on the catch up too if possible :)
I will be looking to tee up a “nasho run” catch up very soon Mate :mrgreen:
SKYHI
Re: Daffy's SE
Postby SKYHI » Fri Nov 22, 2019 11:54 am
Daffy wrote:I will be looking to tee up a “nasho run” catch up very soon Mate :mrgreen:
StanTheMan
Re: Daffy's SE
Postby StanTheMan » Fri Nov 22, 2019 3:57 pm
isnt the Nasho Run in Sin City? :D
Daffy
Re: Daffy's SE
Postby Daffy » Fri Nov 29, 2019 9:55 pm
The new IGN1A coil setup featuring 9.5mm leads is finally up and running! Install went smoothly with no hiccups. Daz took care of the bulk of the wiring work with tuner Matty pinning in the final wiring into the Haltech. After setting the dwell time we done some time on the dyno, dialling in a slightly safer tune for the hot summer coming up, to save on a bit of engine wear and tear until the weather cools again in a few months. The set up looks great and with the bigger gapping (from the old set up gapped @ .5 with the occasional blow out to the new set up gapped @ .8 and no blow out) I have to say I’ve never felt the Problem Child more responsive- no hiccuping or popping, just smooth linear acceleration. Definitely money well spent. :mrgreen:
By the way, the second “catch can” is actually the Problem Childs new radiator overflow bottle- we had to downsize to fit the coils in their new location :DIY:
StanTheMan wrote:isnt the Nasho Run in Sin City? :D
The 1st time we done it in Sin City STM, I thought it was so good we had to have a crack at it in QLD too :lol:
StanTheMan
Re: Daffy's SE
Postby StanTheMan » Sat Nov 30, 2019 5:49 am
what about your cold idle....mot hat its cold atm. :lol:
Users browsing this forum: No registered users and 289 guests
