Any idea on a time frame for completion? I'd love to be back home when you hit the track in this beast. Looking real good mate.
ASE05 wrote:wow ORX626, you should consider opening a shop with your skills.........![]()
ASE05 wrote:Any idea on a time frame for completion? I'd love to be back home when you hit the track in this beast. Looking real good mate.
Mokesta wrote:Can you get your desired camber from the standard adjusters? If not will you modify the front sub frame or put offset rigid bushes in the lower wishbones? If you are going for HUGE camber it may affect your steering measurements.
Mokesta wrote:How is that collector going to get welded out? I expect from the inside and you'll dress the welds for good flow? It looks pretty hard to access from outside.
Mokesta wrote:Keep these updates flowing I'm loving this build.
NMX516 wrote:Great to see this project back on the go Danny!
Fc rotor wrote:Very nice build Danny as per usual.
Read the whole thing from front to where you are now. Can't say that I'm not a little pleased it ended up being 20B PP![]()
although I was quite interested to see how the the charged renesis would perform.
It's amazing just how much projects change over long periods of time, mine has changed upwards of a thousand times in my head so far![]()
It's a long process but glad to see your doing it right
-Marcus
NitroDann wrote:Pretty damned nice
Jeo wrote:What's the white car in the background?
Crapweasel wrote:Mitsubishi Eclipse by the looks
16bit wrote:Jeo wrote:What's the white car in the background?
this
