mrpham's summer build
mrpham
Re: mrpham's summer build
Postby mrpham » Thu Jan 12, 2017 11:17 am
Thanks Mark!
Currently shopping for a 3D printer I can buy and mod :)
Current Forum Specials!
Postby Magpie » Thu Jan 12, 2017 1:21 pm
3D printer, I will have to think about what you could do for me :)
Every time I see a shot of your engine bay I feel a little inadequate... Especially when people ask about where the bonnet rubs on the airbox.
Hopefully this weekend I can clean up my engine bay :)
ImageDSCN3933 by Eipeip, on Flickr
Gladiator
Postby Gladiator » Mon Jan 16, 2017 6:23 am
I'm continually impressed by your build John.
Combustive
Postby Combustive » Sat Jan 21, 2017 9:57 am
This is looking excellent. Nice work!
mrpham
Postby mrpham » Sat Jan 28, 2017 5:14 am
Did some small revisions to my airbox design, also quickly mocked up the rest of the components for it. And looks like I'll probably have the airbox printed using Taulman Nylon Alloy 910, very strong and should hold up against the heat.
Inlet diameter on the airbox is 108mm (4.25"). The duct will be made using laser-cut aluminium sheet, it will also hold the 300mm x 300mm panel filter. I'm planning on mounting the duct under the radiator support alongside a half-sized radiator from a Honda Civic. This should be give me the lowest air temps as well as providing good filtration and high flow.
plohl
Postby plohl » Sat Jan 28, 2017 8:38 am
Looks mad dude.
Are you going to print the piping as well? Or just Al tube it?
plohl
Postby Lokiel » Sat Jan 28, 2017 8:50 am
Are 2 mounting tabs sufficient?
4 would be stronger and less susceptible to twisting (or is there a recessed lip to fit over the lower half on the "intake manifold" - looks like there is).
plohl, I thought it was preferable NOT to use metal plumbing since it heatsoaks.
This has been an issue with many aftermarket CAIs, performance improvements are typically quoted using the first dyno run results, after that subsequent runs tend to be no better, sometimes worse, than the OEM intake because the aftermarket CAI has absorbed so much heat, reducing its efficiency.
If the plumbing is kept on the coldside only, which this looks like, it's probably not as big an issue as if it were on the hotside.
Postby bruce » Sat Jan 28, 2017 11:14 am
Possibly too much of a ram air effect? I know too much air/speed .can be detrimental.
mrpham
Re: RE: Re: mrpham's summer build
Postby mrpham » Sat Jan 28, 2017 12:00 pm
plohl wrote:Looks mad dude.
Unsure hey, would like to print it. The lighter the better.
mrpham
Postby mrpham » Sat Jan 28, 2017 12:04 pm
Lokiel wrote:Are 2 mounting tabs sufficient?
It'll have 4 mounting tabs, supposed to be another 2 in the corners but haven't modelled them in yet. My idea is to use the same mounting plate as the Pipercross filter I'm currently using, keeps it simple and I'll be able to swap between the 2 set-ups easily.
mrpham
Postby mrpham » Sat Jan 28, 2017 12:07 pm
bruce wrote:Possibly too much of a ram air effect? I know too much air/speed .can be detrimental.
I'll look into it now that you've mentioned it, do you know of any info I can read up? I honestly don't know enough about the subject, just been modelling up random things on the plane as I'm travelling atm.
mrpham
Postby mrpham » Sat Jan 28, 2017 12:19 pm
What if I use flexible piping? Would have less heat soak and gets rid of any stresses on the airbox from engine movement.
Postby Magpie » Sat Jan 28, 2017 12:39 pm
Looking forward to the end result. This was similar to a plan I had, 1/2 radiator, 1/4 size air intake and 1/4 oil cooler.
Postby bruce » Sat Jan 28, 2017 5:30 pm
I don't have any references regards the ram air effect. I think it's a physics problem? ie. How much air can the itbs flow
Postby Okibi » Sat Jan 28, 2017 5:45 pm
You might find being in Qld you get a lot of radiant heat off the road/track surface compared to air from the cowl.
