VicRoads wrote: Dear Mr Craddy
VEHICLE IDENTIFICATION NUMBER (VIN): XXXXX
I refer to your email enquiry on 3 August 2015 regarding the above vehicle, which was previously registered in Victoria as a 're-shelled' 1990 Mazda MX5 with number plates OVX100.
A 're-shelled' vehicle is typically an accident damaged that is repaired by utilising an imported body shell.
Re-shelling involved 'transplanting' all serviceable components from the damaged Australian delivered vehicle into the imported body shell under the supervision of a VicRoads Vehicle Assessment Signatory Scheme (VASS) engineer. A new VIN would then be issued and the vehicle is re-certified by a VASS signatory, provided the vehicle meets the Standards for Registration.
During the period of time 're-shelling' was considered a valid repair method, an imported body shell was considered to be 'spare part', and therefore eligible to be used in the repair of a locally delivered variant of the same make and model.
In this particular case, a review of VicRoads records confirms that a 1990 Mazda MX5 with VIN: JM0NA30610010XXXX was damaged in 1998. An imported body shell with Japanese chassis number NA6CE21XXXX was used to repair the original vehicle, and as a result of the certification process, a new VIN: XXXXX was issued to the vehicle.
Please note that re-shelling vehicles of monocoque construction is no longer recognised by VicRoads as a valid repair method. VicRoads continue to recognise vehicles repaired and registered while the re-shelling scheme was in operation, however VicRoads will not recognise or register any recently re-shelled vehicles.
I trust this information assists you. Should you wish to correspond further with VicRoads regarding this matter, please email XXXX.
Kind Regards
Registration and Licensing
Practice and Standards
