Jesse's NA6 from the south
Jessegroves
Postby Jessegroves » Sun Aug 28, 2016 11:21 am
So it's been a long time since I've posted! After getting defected progress was quite slow, but I've done several things since then.
The most major has probably been the tan conversion I did recently.
I bought some original tan carpet from an LHD USDM mx5 and had it shipped over. Having the drivers side swapped in relation to the carpet didn't make a whole lot of difference as the handbrake is still in the same spot and the dead pedal holes in the (now) passenger footwell are covered by the floor mat.
I also purchased some tan seat covers, which were quite an experiment to install
I also purchased some tan vinyl which I used to cover the door cards in the meantime as people wanted way too much for tan door cards.
I used a blade to cut it to shape about 2cm away from the edge so I could fold them over the back and use a staple gun to stick them in place.
I cut slices in the edges where the corners are so they could overlap and sit snug. This was quite a cheap and easy job as mx5 door cards are completely flat :)
I was pretty chuffed at the result in the end! More updates soon :-)
Re: Jesse's NA6 from the south
Postby KevGoat » Sun Aug 28, 2016 12:07 pm
Nicely done! I've always liked the tan interiors.
Sent from my S7 on Tapatalk
Jessegroves
Postby Jessegroves » Sun Aug 28, 2016 12:56 pm
I found some really cheap sill panels on yahoo Japan and had them imported, cost around 75 bucks.
The plastic panels had been damaged and all the paint on the sills had some off and I liked the look of the JDM sill panels Image
speed
Postby speed » Sun Aug 28, 2016 5:26 pm
Nice job on the seats.
Would like to see more pics of the seats and door trims when you have the time. They look sensational and go very well with the red and black.
Jessegroves
Postby Jessegroves » Sun Aug 28, 2016 6:18 pm
speed wrote:Nice job on the seats.
Cheers bud :)
I bought 2 seat covers from a trim company from the US for 300, each seat comes in 2 separate pieces and the original covers have to removed first.
The door panels were super easy, just bought a sheet of tan vinyl for $15 bucks, was enough to cover the door.
I layed it over the original door card and traced around it etc and just stapled it over the original black so I can remove it if I want.
Jessegroves
Postby Jessegroves » Mon Aug 29, 2016 2:24 pm
My rotors were pretty old and they needed replacing so I bought a pair of oem rear rotors and dba slotted rotors for the front because why not!
I probably should of done pads at the same time but ah well, not a difficult job.
Heres how they came.
Jessegroves
Postby Jessegroves » Wed Aug 31, 2016 7:08 pm
After being defected I wanted to find a nice set of wheels with a less aggressive offset. I found a set of 15x7 Koya Supersports, so I shipped them over and fitted them
Just waiting for coilovers, and they should sit perfect :)
Jessegroves
Postby Jessegroves » Sun Sep 04, 2016 10:19 am
So I finally got my coilovers in this weekend!
Yellowspeed Dynamic Pro's
Didn't take too long to install, at first it was so low that the wheel constantly scrubbed the guard when turning, so some adjustments had to me made, now they sit alright but the rears need to come down a bit more,
Overall, so happy with the result, looks great and most of all, handles amazingly :)
speed
Postby speed » Sun Sep 04, 2016 7:19 pm
Sweet. I have the same coilovers that I'm yet to fit.
Jessegroves
Postby Jessegroves » Sun Sep 04, 2016 8:59 pm
speed wrote:Sweet. I have the same coilovers that I'm yet to fit.
They're great!
Jessegroves
Postby Jessegroves » Sun Jul 23, 2017 2:29 pm
Garage Vary finish panel! Need to fab up some brackets for the far edges, should look good
Postby Okibi » Sun Jul 23, 2017 11:01 pm
Nice, can't wait to see it painted.
Postby KevGoat » Sun Jul 23, 2017 11:07 pm
All coming together nicely
Jessegroves
Postby Jessegroves » Sun Jul 23, 2017 11:13 pm
Spent Sunday Afternoon modding na8 mirrors to fit an na6. I liked the look of the electric mirrors much better and they seem to flow with the body a lot nicer. I picked up a set cheap and fitted them, only issue is there over 3x heavier than the 6 mirrors at 1kg over 290g. ImageImage
The plan is to respray the car, have had a few quotes, and I'm almost ready, I'm still unsure to keep it red again or go with a 95 M Edition Merlot. I think the latter. Image
speed
Postby speed » Mon Jul 24, 2017 9:41 pm
Looking great. Wish i had power mirrors!
I'd have to see the merlot with tan seats before i can be convinced. Sounds fine in my head but we all know red is a winner :)
